jcontova
Joined: 28 May 2024 Posts: 3 Location: Los Angeles, CA
Posted: Tue May 28, 2024 2:22 pm Post subject: New 924 Turbo Owner. Headlight Bulb Question. |
I am a proud new owner of a '81 924 turbo! I have started to address some things that need replacing on the car and one of these is the passenger headlight. I wanted to know if anyone has any detailed knowledge of the types/brands/PNs of bulbs that would have been factory equipped on an 81 turbo (car is extremely low miles and I want to retain its concours quality). I suspect that the bulbs I currently have are factory original but I wanted to confirm here. They are General Electric H6014 bulbs. I have been unable to find any for sale online of even a photo of an identical bulb except for one listed on Performance Products site here:
https://ppeporparts.com/i-30519918-crystal-vision-ultra-headlight-bulbs-halogen.html#!model%3D924%20TURBO%7C%7Cmake%3DPORSCHE%7C%7Cyear%3D1981
This bulb looks identical to mine, but these look like repros with possibly a non-sealed beam type construction. I have found a few 6014 GE bulbs on Ebay but they lack the H in the part number and the 'HALOGEN' writing on the center of the glass lens.
Anyway, before I go down a rabbit hole of trying to locate NOS H6014s I wanted to confirm that these are indeed factory original (or just factory correct).
Thanks! _________________ 1981 924 Turbo |
Beartooth
Posted: Tue May 28, 2024 4:48 pm Post subject: |
I couldn't tell you what exactly they came from the factory with, but it's a standard 7" round sealed beam headlight. You can still get 6014s, it seems, but the halogen version (6024 - I think the only difference is it's halogen) is more commonly available and brighter anyway. I went with Hella's H4 conversion, which gives you the sharper, euro-style beam pattern and more brightness yet; I'm pretty happy with it, but I might upgrade to relays just to squeeze a bit more out of it yet. Lastly, there are LED 7" conversions available. Philips and Sylvnaia both make them - but they're more expensive, and you've gotta buy a whole new headlight if it quits on you. _________________ 1980 931 diamond in the rough |
Posted: Tue May 28, 2024 8:36 pm Post subject: |
| Beartooth wrote: | | I couldn't tell you what exactly they came from the factory with, but it's a standard 7" round sealed beam headlight. You can still get 6014s, it seems, but the halogen version (6024 - I think the only difference is it's halogen) is more commonly available and brighter anyway. I went with Hella's H4 conversion, which gives you the sharper, euro-style beam pattern and more brightness yet; I'm pretty happy with it, but I might upgrade to relays just to squeeze a bit more out of it yet. Lastly, there are LED 7" conversions available. Philips and Sylvnaia both make them - but they're more expensive, and you've gotta buy a whole new headlight if it quits on you. |
Its mind boggling that there can be less light than the euro H4 They must barely be glowing:) _________________ 1980 924 Turbo
Beartooth
Posted: Wed May 29, 2024 4:12 am Post subject: |
I can't argue with that: the US Department of Transportation came up with a byzantine standard for headlights in the 40s and 50s that took a long time to back down from, and their mindset still lags far behind current technology. Halogen bulbs squeezed a little more out of the DOT standard, but still had a crummy beam pattern and were limited to 35W on low beam. So the extra 20W low beam and more focused beam on euro H4s makes a difference. They're also still not entirely legal in the US, depending on who you ask...
What's even more mind-boggling is, it wasn't until the mid-80s when automakers were able to break from the old sealed headlights - and it was Ford who spear-headed that by arguing that flush, integral headlights would improve fuel efficiency. It wasn't even the more obvious safety advantage that tipped the scales.
I'm big on headlights because I live in an area where deer are everywhere (Montana has the second-highest rate for deer strikes in the US), and the best possible headlight, properly aimed, could be the difference between seeing and avoiding a deer and a smashed-up car (or worse). My Mercedes have euro headlights that are also a big improvement, but unfortunately, my 560SEC is still awaiting repair after hitting a deer a few years back... _________________ 1980 931 diamond in the rough |
Posted: Wed May 29, 2024 5:34 am Post subject: |
| Beartooth wrote: | I can't argue with that: the US Department of Transportation came up with a byzantine standard for headlights in the 40s and 50s that took a long time to back down from, and their mindset still lags far behind current technology. Halogen bulbs squeezed a little more out of the DOT standard, but still had a crummy beam pattern and were limited to 35W on low beam. So the extra 20W low beam and more focused beam on euro H4s makes a difference. They're also still not entirely legal in the US, depending on who you ask...
Interesting..Yeah, twisty country roads in the dark can be a challenge, i dont enjoy it that much in the 924. Would anyone care or notice an H4 uppdate on an old car like this?
I'm big on headlights because I live in an area where deer are everywhere (Montana has the second-highest rate for deer strikes in the US), and the best possible headlight, properly aimed, could be the difference between seeing and avoiding a deer and a smashed-up car (or worse). My Mercedes have euro headlights that are also a big improvement, but unfortunately, my 560SEC is still awaiting repair after hitting a deer a few years back... |
Legitimate Salvage
Posted: Wed Jul 17, 2024 9:12 pm Post subject: |
I ordered/installed a pair of these Koito H4 headlights in my '79 924.
https://www.busdepot.com/h6024k
Perfect fit and an order of magnitude better light than the sealed beam halogens that were in it. Very nice low beam cutoff. Made a world of difference in nighttime driving. The lens itself has a flatter profile than the original sealed beams. Not a deal breaker for me.
In another life I owned an '84 Mercedes 300D. I put a similar pair on that car and got the same outstanding improvement in lighting.
I have no advice on finding a set of NOS sealed beams from the late 70's/early 80's. Maybe ePay? If you do get a pair, don't drive your baby at night.
