Nathaen
Posted: Fri Apr 03, 2020 2:50 am Post subject: Remove Fuel Distributor 1982 924 |
| The Fuel Distributor is a very expensive part that is low in supply so I was curious if there is a way to get rid of it permanently. I am new to the car so I am trying to find a permanent alternative. |
gerben1986
Joined: 13 Mar 2008 Posts: 232 Location: The Netherlands
Posted: Fri Apr 03, 2020 3:45 am Post subject: |
Rebuild? _________________ 911SC - 1980 |
Nathaen
Posted: Fri Apr 03, 2020 5:30 am Post subject: |
| gerben1986 wrote: | | Rebuild? |
I'm going to get it rebuilt. Was looking to see if there is alternative fuel systems that are swappable because it seems as though distributors go out fairly quickly and it's going to be annoying when I have to do it again. |
Posted: Fri Apr 03, 2020 8:43 am Post subject: |
Well you could go retro and put on carbs, or higher tech and go with Mega-Squirt. Both will require a lot of fiddling.  _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
safe
Posted: Fri Apr 03, 2020 6:37 pm Post subject: |
| EFI, no matter if you choose EFI, carbs, it will likely cost more than the car is worth. But at least EFI will be sweet. I don't understand carbs, why you would want that unless you like the old school look or is limited by regulations. |
Posted: Fri Apr 03, 2020 6:44 pm Post subject: |
| Nathaen wrote: | | it seems as though distributors go out fairly quickly |
What? if you have it properly rebuilt and dont put diesel, sand and twigs into your fuel tank the next time you're going to have to rebuild the distributor is probably in 40 years...is that fairly quickly to you?
Also...how do you know its the dizzy and not the WUR? _________________ Supercharger and EFI kits
https://www.the924.com |
Posted: Sat Apr 04, 2020 11:49 am Post subject: |
What Morghan said.
I rebuilt the fuel distributor in my race car with a kit and resealed it with Loctite 542 spread between the plates with a razor blade. Have been winning races for two years.  _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
Posted: Sat Apr 04, 2020 8:19 pm Post subject: Re: Remove Fuel Distributor 1982 924 |
| Nathaen wrote: | | The Fuel Distributor is a very expensive part that is low in supply so I was curious if there is a way to get rid of it permanently. I am new to the car so I am trying to find a permanent alternative. |
Why? A good working CIS should be as reliable as any. Is there anything currently wrong with the distributor? An EFi solution will cost as much as refurbing the existing CIS system. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
