Remove Fuel Distributor 1982 924
Nathaen
PostPosted: Fri Apr 03, 2020 2:50 am    Post subject: Remove Fuel Distributor 1982 924 Reply with quote
The Fuel Distributor is a very expensive part that is low in supply so I was curious if there is a way to get rid of it permanently. I am new to the car so I am trying to find a permanent alternative.
gerben1986
PostPosted: Fri Apr 03, 2020 3:45 am    Post subject: Reply with quote
Rebuild?
911SC - 1980
Nathaen
PostPosted: Fri Apr 03, 2020 5:30 am    Post subject: Reply with quote
gerben1986 wrote:
Rebuild?
I'm going to get it rebuilt. Was looking to see if there is alternative fuel systems that are swappable because it seems as though distributors go out fairly quickly and it's going to be annoying when I have to do it again.
PostPosted: Fri Apr 03, 2020 8:43 am    Post subject: Reply with quote
Well you could go retro and put on carbs, or higher tech and go with Mega-Squirt. Both will require a lot of fiddling.
1981 924 Turbo sold
1982 924 Turbo sold
safe
PostPosted: Fri Apr 03, 2020 6:37 pm    Post subject: Reply with quote
EFI, no matter if you choose EFI, carbs, it will likely cost more than the car is worth. But at least EFI will be sweet. I don't understand carbs, why you would want that unless you like the old school look or is limited by regulations.
PostPosted: Fri Apr 03, 2020 6:44 pm    Post subject: Reply with quote
What? if you have it properly rebuilt and dont put diesel, sand and twigs into your fuel tank the next time you're going to have to rebuild the distributor is probably in 40 years...is that fairly quickly to you?
Also...how do you know its the dizzy and not the WUR?
PostPosted: Sat Apr 04, 2020 11:49 am    Post subject: Reply with quote
What Morghan said.
I rebuilt the fuel distributor in my race car with a kit and resealed it with Loctite 542 spread between the plates with a razor blade. Have been winning races for two years.
1981 924 Turbo sold
1982 924 Turbo sold
PostPosted: Sat Apr 04, 2020 8:19 pm    Post subject: Re: Remove Fuel Distributor 1982 924 Reply with quote
Why? A good working CIS should be as reliable as any. Is there anything currently wrong with the distributor? An EFi solution will cost as much as refurbing the existing CIS system.
