Got a MAF? Then you need one of these..
Tam Lin
PostPosted: Wed Sep 15, 2010 10:58 pm    Post subject: Got a MAF? Then you need one of these.. Reply with quote
My 924S has a 944S2 3 L motor, and since about May, a Vitesse MAF with piggyback. The reason for the MAF was primarily to improve low end response, which I felt was lacking with the OEM AFM.
One of the issues with MAFs is that they are very sensitive to turbulence, and prefer to see about a foot of pipe before e.g. a K&N filter install. With a LARGE filter behind the light bucket, that was just not going to happen.
After MAF ibnstall, I had surging from low speed, but a much improved top end: Not at all what I expected beforehand!
I did some research, and came across this: http://www.saxonpc.com/100mm-cells-for-100.html It's cheap, and the delivery service received from them was excellent, given I'm in the UK. Result: No more surging.
I have no connection to them whatsoever, but if you've got a MAF without a decent propper large filter chamber, I hope this solution helps..
PostPosted: Wed Sep 15, 2010 11:21 pm    Post subject: Reply with quote
The 2.0L do not use an MAF FYI.
Min
PostPosted: Wed Sep 15, 2010 11:55 pm    Post subject: Reply with quote
I find this information useful, thank you for posting it
Min
PostPosted: Thu Sep 16, 2010 12:12 am    Post subject: Reply with quote
Yeah, and neither does my lawnmower. FYI.
ic932
PostPosted: Thu Sep 23, 2010 12:42 am    Post subject: Reply with quote
Min
Yeah me too, cheers for sharing.
Yeah but the 2.5S model could do, and therefore this is sound performance related info.
Rich H
PostPosted: Thu Sep 23, 2010 12:48 am    Post subject: Reply with quote
Interesting stuff...
trey3670
PostPosted: Wed Nov 03, 2010 1:10 am    Post subject: Reply with quote
where do you mount this thing? inside the mass airflow sensor? so after the filter?
PostPosted: Wed Nov 03, 2010 2:53 am    Post subject: Reply with quote
Wow, that makes a lot of sense, very cool, thanks for posting!
bnoon
PostPosted: Sun Nov 07, 2010 12:27 am    Post subject: Reply with quote
You mount it in the MAF tubing right before the actual sensor. The cells straighten air flow for more accurate MAF thermal transfer. This is an advantage at low speeds where air turbulence can cause the MAF readings to be all over the place (which causes ECU fuel demand to be all over the place). It's really a fuel saver and performance mod all in one for cars without honecomb cells in their MAF stock, especially custom installs.
'80 924 Turbo - SOLD!
1986 Porsche 944 Turbo - SOLD!
Porscheless
Martijnus
PostPosted: Sun Nov 07, 2010 2:08 am    Post subject: Reply with quote
I like this info too.
Not that I'm using a MAF, but i could... and this seems sensible.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
