Tam Lin
Joined: 17 Dec 2008 Posts: 15 Location: Near London, Great Britain
Posted: Wed Sep 15, 2010 10:58 pm Post subject: Got a MAF? Then you need one of these.. |
My 924S has a 944S2 3 L motor, and since about May, a Vitesse MAF with piggyback. The reason for the MAF was primarily to improve low end response, which I felt was lacking with the OEM AFM.
One of the issues with MAFs is that they are very sensitive to turbulence, and prefer to see about a foot of pipe before e.g. a K&N filter install. With a LARGE filter behind the light bucket, that was just not going to happen.
After MAF ibnstall, I had surging from low speed, but a much improved top end: Not at all what I expected beforehand!
I did some research, and came across this: http://www.saxonpc.com/100mm-cells-for-100.html It's cheap, and the delivery service received from them was excellent, given I'm in the UK. Result: No more surging.
I have no connection to them whatsoever, but if you've got a MAF without a decent propper large filter chamber, I hope this solution helps.. |
Posted: Wed Sep 15, 2010 11:21 pm Post subject: |
The 2.0L do not use an MAF FYI. _________________ [This Space For Rent] |
Min
Posted: Wed Sep 15, 2010 11:55 pm Post subject: |
I find this information useful, thank you for posting it
Posted: Thu Sep 16, 2010 12:12 am Post subject: |
| flosho wrote: | | The 2.0L do not use an MAF FYI. |
Yeah, and neither does my lawnmower. FYI. _________________ Toofah King Bad
ic932
Posted: Thu Sep 23, 2010 12:42 am Post subject: |
| Min wrote: | I find this information useful, thank you for posting it
Min |
Yeah me too, cheers for sharing.
Yeah but the 2.5S model could do, and therefore this is sound performance related info. |
Rich H
Posted: Thu Sep 23, 2010 12:48 am Post subject: |
Interesting stuff... _________________ 1994 Lotus Esprit S4 - Work in progress...
trey3670
Posted: Wed Nov 03, 2010 1:10 am Post subject: |
| where do you mount this thing? inside the mass airflow sensor? so after the filter? |
Posted: Wed Nov 03, 2010 2:53 am Post subject: |
Wow, that makes a lot of sense, very cool, thanks for posting! _________________ Vaughan Scott
bnoon
Joined: 12 Oct 2009 Posts: 607 Location: West Des Moines, IA USA
Posted: Sun Nov 07, 2010 12:27 am Post subject: |
| trey3670 wrote: | | where do you mount this thing? inside the mass airflow sensor? so after the filter? |
You mount it in the MAF tubing right before the actual sensor. The cells straighten air flow for more accurate MAF thermal transfer. This is an advantage at low speeds where air turbulence can cause the MAF readings to be all over the place (which causes ECU fuel demand to be all over the place). It's really a fuel saver and performance mod all in one for cars without honecomb cells in their MAF stock, especially custom installs. _________________ '80 924 Turbo - SOLD!
1986 Porsche 944 Turbo - SOLD!
Porscheless  |
Martijnus
Posted: Sun Nov 07, 2010 2:08 am Post subject: |
I like this info too.
Not that I'm using a MAF, but i could... and this seems sensible. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
