ANYONE DOING ANYTHING EXCITING ON THEIR CAR ?
Goto page Previous  1, 2, 3 ... 12, 13, 14 ... 150, 151, 152  Next
v8carreragts
PostPosted: Wed Apr 28, 2010 10:14 am    Post subject: Reply with quote
I got one flare bonded and I found replacement rubber trailing arm bushings. Now you're not stuck with delrin or urethane. Paragon Products has a set for the 911. (4 identical bushings) The outers are the same but the inners need 1/2" cut from them to fit. They have a note about this under the listing so I called and asked. they fit perfectly.
PostPosted: Thu Apr 29, 2010 3:46 pm    Post subject: Reply with quote
Yea bout ready to put on the flairs have the front susp. off and am grinding the inner fenders.. in front.
PostPosted: Thu Apr 29, 2010 11:53 pm    Post subject: Reply with quote
That looks real good! Do you mind my asking what are you using to bond the flairs?
v8carreragts
PostPosted: Fri Apr 30, 2010 12:01 am    Post subject: Reply with quote
[quoteThat looks real good! Do you mind my asking what are you using to bond the flairs?[/quote]
I'm using 3M 08115 Automix Panel adhesive. I bought it on e-bay with the applicator gun. I think the gun was about $40 and the epoxy is $32. I only did one flare because I used more than 1/2 of the one 500ml cartridge for the first flare. Another cartridge should be here today.
I used this because the tech rep from 3M recomended it.
PostPosted: Fri Apr 30, 2010 12:23 am    Post subject: Reply with quote
I used this because the tech rep from 3M recomended it.[/quote]
Thanks for the tip! Let us know what you think later
smart931
PostPosted: Fri Apr 30, 2010 1:16 am    Post subject: Reply with quote
Pretty sure this is only exciting for me... but. I finally managed to get my car through smog yesterday. It's been off the road with a mystery problem since January. Hired mechanics to fix it with no luck. Finally, through Pelican forum and here and my brothers comment, i tracked the problem down to the DITC connector.
This is my daily, so it's a huge weight off my mind.
Gonna take it for a drive through Big Sur to celebrate.
Man, it's so good to feel the thrust of the turbo again.
1982 Porsche 931 (Sold)
2000 Smart Fortwo (Waiting for import)
1972 Opel manta (Left in England)
1965 Chevrolet Corvair (Left in England)
2010 Mazda 3 (Ex got this in divorce)
1974 Triumph TR6 (sadly gone)
1968 Ford F250 Camper Special (Daily)
PostPosted: Fri Apr 30, 2010 2:00 am    Post subject: Reply with quote
I think every one of us has been through this at one time or another.
PostPosted: Fri Apr 30, 2010 2:05 am    Post subject: Reply with quote
Well the right side is ready for outer body prep for flair install.
The number 8 framing screws idealy, used in .25 guage metal
I put 2 in each tab & on the ends 3 inch off angle. Its ready to
be rubberised with coating. I can now do the same to the left side.
Then I can bond my flairs..
Today Im shooting for getting the front inner fenderwells
all free of old coating, left side is bout done probly a few hrs
there before i start on the other side.
Also front calipers need cleaned, stripped and repainted
Hubs need to be blasted after I stripped them...dont ever paint
five lug front hubs, and the inner frame rails on the body & control
arms need attention before i finish by drillen the under side of the nose panel ... after all this is done I can start on the body work.
& of course out that time Ill be planning cooler install and removing
turbo motor.
Sounds like to much info though its not.
AppleBit
PostPosted: Sat May 01, 2010 12:36 am    Post subject: Reply with quote
I will be revealing my car (and the new look) tomorrow at Minneapolis Motorplex's Cars and Cafe! I'll post pics at that point!
Classic British Sports Car Restoration v6 + v8 Engine Conversion Swaps
Porsche 924 Wide Body LS1 Corvette 500 Horsepower Engine
skemcin
PostPosted: Sat May 01, 2010 1:34 am    Post subject: Reply with quote
I'm excited for you AB - wish I could be there. Your car looks awesome given the pics shared so far.
Enjoy.
924.org (no time to complete)
9249206346 - 89k – new shifter bushings, belts, running well.
9249206347 - 8k – waiting its resurrection, no power at the fuel pump and fuse #7 blows w/power
xpernet
PostPosted: Sat May 01, 2010 8:03 am    Post subject: Reply with quote
Well, ive been pretty busy the past couple of months sourcing the parts to convert the front end to an S2/Turbo look. Now im just sanding down the body, then a lot of fiberglassing, bondo and paint. I should have a good looking toofah by the end!
... i just got to figure out how to fiberglass the back end together. The rear bumper was meant for a 944 so as you can see it doesnt like the CGT Flares.
1977 Porsche 924
Sunroof Delete
Megasquirt II EFI & EDIS
Carrera GTS / 944 Body
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
PostPosted: Wed May 05, 2010 3:55 am    Post subject: Reply with quote
I would throw out the rear bumper its ugly to me expernet if it was mine.
you have to decide if you want to mess with the gt look ya got there.
Me Im starting 2 clean up my brake calis & front control arms...
JayZzzz4
PostPosted: Wed May 05, 2010 9:06 am    Post subject: Reply with quote
Took a nice drive downtown and around to the lake front, most beautiful day yet in Wisconsin, 78 degrees. As I was driving by the lake, I spotted a black 928 following right behind me. I can't ask for a better time in the Porsche then this.
White 1987 Porsche 924S manual
PostPosted: Wed May 05, 2010 10:02 am    Post subject: Reply with quote
Yea drivin it thats exciting Im paint stripping brake calipers
& discovering torn piston ass. seals.
Tas931
PostPosted: Wed May 05, 2010 10:47 am    Post subject: Reply with quote
pulled the front struts out last night...
Turbo is on mates bench being rebuilt (parts should be here this week)
New Slotted rotors on the way
Volvo 4 spot callipers to put on
Clutch slave rebuild kit on the way
gotta go order front shocks
Then it's over the pits and back into driving freedom
Page 13 of 152
