Wrapping exhaust manifold pipe
datatrain
PostPosted: Tue Jan 20, 2009 5:59 am    Post subject: Wrapping exhaust manifold pipe Reply with quote
Obviously I have too much time on my hands...
Is there any advantage to putting heat insulating material around the pipe from the manifold to the catalytic. Other than protecting the plug wires from high heat ? I seem to recall quite a few years ago there was panel of material glued to the body near the manifold.
Will it overheat the cat if I do ?
I'm guessing the best material would be asbestos but it's probably no longer for sale. I'm not sure fibreglass could take the high temps.
Thnx
DAve
'78 924 NA with Collector plate
33 year old car, with me for 21 yrs
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR
PostPosted: Tue Jan 20, 2009 6:07 am    Post subject: Reply with quote
I'd be very concerned about the higher operating temp of the pipes killing them. BTDT with my last header.
Chrenan
Hot exhaust gas flows quicker, which is why folks like to keep heat in the exhaust piping through wrapping, thermal coating etc. Keeping heat in is very important in a turbo motor as it can help lower the spool-up time. Can also play an important role in an NA motor to help scavenge during the exhuast cycle of the engine.
However, if you wrap your header or any exhaust pipes close to the engine, be very, very wary of oil leaks. Even a slow drip can soak exhaust wrap over time. Heat + oily cloth = BBQ.
Rich H
PostPosted: Tue Jan 20, 2009 8:50 am    Post subject: Reply with quote
If you like not itching then I would give it a miss...BTDT
PostPosted: Tue Jan 20, 2009 11:33 am    Post subject: Reply with quote
Ceramic coating is the way to go IMO.
Martijnus
PostPosted: Wed Jan 21, 2009 7:47 am    Post subject: Reply with quote
I've been told the exhaust will corrode way faster when it's wrapped in material... didn't get any explanation though...
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Rich H
PostPosted: Wed Jan 21, 2009 7:57 am    Post subject: Reply with quote
A bigger problem as has been mentionned is the heat, the manifold stays hotter and for longer than it normally would which can mean cracking. Also remember that heat that could not escape is now being shunted further down the system so more of the exhaust gets hotter too.
PostPosted: Wed Jan 21, 2009 7:59 am    Post subject: Reply with quote
Condensation under the wrapping can't be good...
PostPosted: Wed Jan 21, 2009 10:58 pm    Post subject: Reply with quote
My racecar saw the wet maybe once or twice with the last header (which was wrapped and failed within 2 yrs). It was the excessive heat buildup that killed it; pipes split, and the metal was scaling away, not corroded.
The manufacturer explicitly recommends against wrapping, BTW.
Rich H
PostPosted: Wed Jan 21, 2009 11:02 pm    Post subject: Reply with quote
In short, don't do it...
datatrain
PostPosted: Thu Jan 22, 2009 8:16 am    Post subject: Reply with quote
You guys all convinced me it's a bad idea.
Thnx
Mint '92 318i BMW
VE7HFR
Martijnus
PostPosted: Thu Jan 22, 2009 8:37 am    Post subject: Reply with quote
well... you wrap the pipes because you want a higher temperature in the exhaust, but that same thing will kill your manifold..
easy choice
I've got a manifold in which the barrier between the 2 banks has vanished... I guess it's a combination of a lean mixture and wrong ignition timing.
