datatrain
Joined: 15 Sep 2007 Posts: 441 Location: Osoyoos, British Columbia
Posted: Tue Jan 20, 2009 5:59 am Post subject: Wrapping exhaust manifold pipe |
Obviously I have too much time on my hands...
Is there any advantage to putting heat insulating material around the pipe from the manifold to the catalytic. Other than protecting the plug wires from high heat ? I seem to recall quite a few years ago there was panel of material glued to the body near the manifold.
Will it overheat the cat if I do ?
I'm guessing the best material would be asbestos but it's probably no longer for sale. I'm not sure fibreglass could take the high temps.
Thnx
DAve _________________ '78 924 NA with Collector plate
33 year old car, with me for 21 yrs
Mint '92 318i BMW
Near mint '98 Buick LeSabre
VE7HFR |
Joined: 29 Jul 2001 Posts: 9073 Location: Royal Oak, MI, USA
Posted: Tue Jan 20, 2009 6:07 am Post subject: |
I'd be very concerned about the higher operating temp of the pipes killing them. BTDT with my last header. _________________ Vaughan Scott
Chrenan
Hot exhaust gas flows quicker, which is why folks like to keep heat in the exhaust piping through wrapping, thermal coating etc. Keeping heat in is very important in a turbo motor as it can help lower the spool-up time. Can also play an important role in an NA motor to help scavenge during the exhuast cycle of the engine.
However, if you wrap your header or any exhaust pipes close to the engine, be very, very wary of oil leaks. Even a slow drip can soak exhaust wrap over time. Heat + oily cloth = BBQ. _________________ 1987 951 - M193 Version for Japan |
Rich H
Posted: Tue Jan 20, 2009 8:50 am Post subject: |
If you like not itching then I would give it a miss...BTDT _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Tue Jan 20, 2009 11:33 am Post subject: |
Ceramic coating is the way to go IMO. _________________ erstwhile owner of just about every 924 variant ever made |
Martijnus
Posted: Wed Jan 21, 2009 7:47 am Post subject: |
I've been told the exhaust will corrode way faster when it's wrapped in material... didn't get any explanation though... _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Rich H
Posted: Wed Jan 21, 2009 7:57 am Post subject: |
A bigger problem as has been mentionned is the heat, the manifold stays hotter and for longer than it normally would which can mean cracking. Also remember that heat that could not escape is now being shunted further down the system so more of the exhaust gets hotter too. _________________ 1994 Lotus Esprit S4 - Work in progress...
Posted: Wed Jan 21, 2009 7:59 am Post subject: |
| Martijnus wrote: | | I've been told the exhaust will corrode way faster when it's wrapped in material... didn't get any explanation though... |
Condensation under the wrapping can't be good...
69 911 |
Posted: Wed Jan 21, 2009 10:58 pm Post subject: |
My racecar saw the wet maybe once or twice with the last header (which was wrapped and failed within 2 yrs). It was the excessive heat buildup that killed it; pipes split, and the metal was scaling away, not corroded.
The manufacturer explicitly recommends against wrapping, BTW. _________________ Vaughan Scott
Rich H
Posted: Wed Jan 21, 2009 11:02 pm Post subject: |
In short, don't do it...  _________________ 1994 Lotus Esprit S4 - Work in progress...
datatrain
Posted: Thu Jan 22, 2009 8:16 am Post subject: |
You guys all convinced me it's a bad idea.
Thnx _________________ '78 924 NA with Collector plate
Mint '92 318i BMW
VE7HFR |
Martijnus
Posted: Thu Jan 22, 2009 8:37 am Post subject: |
well... you wrap the pipes because you want a higher temperature in the exhaust, but that same thing will kill your manifold..
easy choice
I've got a manifold in which the barrier between the 2 banks has vanished... I guess it's a combination of a lean mixture and wrong ignition timing. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
