A Little History Lesson
bruce76-924
PostPosted: Mon May 21, 2007 2:26 am    Post subject: Reply with quote
Guys,
The 924 GTP was as Raceboy shows - 16 valve 2.5 litre and turbocharged. It didn't use the same head as any production 944 and likewise Porsche didn't build a 16 valve turbo 944. Even the short run of 968 turbos used the 8 valve 2.5 litre 951 engine. The engine picture that Morghen posted is not an original GTP engine.
Bruce.
1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox.
Raceboy
PostPosted: Mon May 21, 2007 2:35 am    Post subject: Reply with quote
Bruce.
And I'm still going to call my white 924 a "GTP" after the 2.5 liter 16valve turbo engine is in! Even though it has S head.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
dpw928
PostPosted: Mon May 21, 2007 3:39 am    Post subject: Reply with quote
That picture does look like the one I saw and agreed it does have a DOHC. Anyone else notice that the real one doesn't have nose vents?
Dennis
81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black
PostPosted: Mon May 21, 2007 3:47 am    Post subject: Reply with quote
944 Turbo S?
PostPosted: Mon May 21, 2007 4:07 am    Post subject: Reply with quote
Yea raceboy the gtp motor was a thing of beauty I thuink there may be only one or 2 left intact if memory serves me well.. you seem pretty stoked on the gtp though I am too much more than the gtr.
924 turbo
PostPosted: Mon May 21, 2007 4:33 am    Post subject: Reply with quote
944 Turbo S?
Not 16v. Even the 968 Turbo S/RS used the 8v head.
Jon Furst
bruce76-924
PostPosted: Mon May 21, 2007 4:57 am    Post subject: Reply with quote
Best of all, at 1.1 bar of boost ( for endurance racing ) they put out a quoted 420 bhp, but could have the boost wound up to 1.5 bar and produce 500 bhp. Kind of beats the average production 951!
Cheers, Bruce.
Raceboy
PostPosted: Mon May 21, 2007 5:38 am    Post subject: Reply with quote
Since it's a bit OT, but.....GTP spec engine would yield 500-550 hp @ 1-1.2 bar with Garrett GT35R that I'm going to use. It will be a killer combo: generously flowing head compared to modern ball-bearing and fast-spooling turbo.
I already have all the parts needed (2.5 block, 951 pistons, S head, new stainless valves, seals, bearings, turbo etc) sans clutch. I'll use S2 flywheel (60-2 tooth ring) not 951 flywheel and I'll have to find the best 225mm (like 931) clutch available.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
PostPosted: Mon May 21, 2007 5:40 am    Post subject: Reply with quote
awesome
dpw928
PostPosted: Mon May 21, 2007 6:35 am    Post subject: Reply with quote
Don't know how it would fit but the high HP 928 racers are going back to the early 928 twin disc clutch setup.
Dennis
81 931 5 sp
78 928 5 sp Silver
bruce76-924
PostPosted: Mon May 21, 2007 7:57 am    Post subject: Reply with quote
Raceboy,
If you can build it ( and I'm pretty sure you can), then we can let you call a GTP!!! After all, I read that the P in GTP refered to prototype and I guess your motor would fit that description..... good luck with it.
Cheers, Bruce.
J1NX3D
PostPosted: Mon May 21, 2007 10:00 am    Post subject: Reply with quote
dpw928 wrote:
BTW the engine pictured above appears to be a 944S engine due to the single timing gear. Also, that appears to be a production head, not a one off (or 4 off) developmental head.
Dennis
yes thats right. people are confusing the 924 gtp ( with the 944 dohc turbo engine) and the 944 gtp ( with the S or S2 engine, i cant remember which.)
'86 944
PostPosted: Mon May 21, 2007 6:24 pm    Post subject: Reply with quote
no, the picture that i posted is indeed a 944 dohc engine and i've only re-posted the picture because paul's post did not show the picture.
As i know the GTP has indeed a DOHC engine i've seen that picture and i had others with close-ups on that engine but i lost them.
J1NX3D
PostPosted: Tue May 22, 2007 8:37 am    Post subject: Reply with quote
This engine:
lives in this 944 gtp:
this is the 924 gtr engine:
http://forums.pelicanparts.com/showthread.php?s=&threadid=292822&highlight=carrera+gtr
i dont think ive ever seen engine pics of the 924 gtp (944 turbo engined).
'86 944
Raceboy
PostPosted: Tue May 22, 2007 3:58 pm    Post subject: Reply with quote
924 GTP is NOT 944 Turbo engined! This was a prototype 16valve turbo engine and none of the 924/944/968 turbocharged engines were released with 16valve heads.
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Page 2 of 3
