bruce76-924
Joined: 22 Feb 2007 Posts: 105 Location: Bradford, England
Posted: Mon May 21, 2007 2:26 am Post subject: |
Guys,
The 924 GTP was as Raceboy shows - 16 valve 2.5 litre and turbocharged. It didn't use the same head as any production 944 and likewise Porsche didn't build a 16 valve turbo 944. Even the short run of 968 turbos used the 8 valve 2.5 litre 951 engine. The engine picture that Morghen posted is not an original GTP engine.
Bruce. _________________ 1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
1.8t engine conversion with Holset turbo and 6 speed Audi gearbox. |
Raceboy
Posted: Mon May 21, 2007 2:35 am Post subject: |
| bruce76-924 wrote: | It didn't use the same head as any production 944 and likewise Porsche didn't build a 16 valve turbo 944.
Bruce. |
And I'm still going to call my white 924 a "GTP" after the 2.5 liter 16valve turbo engine is in! Even though it has S head. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
dpw928
Joined: 02 Nov 2002 Posts: 1860 Location: owasso, ok 74055
Posted: Mon May 21, 2007 3:39 am Post subject: |
That picture does look like the one I saw and agreed it does have a DOHC. Anyone else notice that the real one doesn't have nose vents?
Dennis _________________ 81 931 5 sp
78 928 5 sp Silver
78 928 AT Euro Black |
Posted: Mon May 21, 2007 3:47 am Post subject: |
| bruce76-924 wrote: | | It didn't use the same head as any production 944 and likewise Porsche didn't build a 16 valve turbo 944. |
944 Turbo S? _________________ Toofah King Bad
Posted: Mon May 21, 2007 4:07 am Post subject: |
Yea raceboy the gtp motor was a thing of beauty I thuink there may be only one or 2 left intact if memory serves me well.. you seem pretty stoked on the gtp though I am too much more than the gtr.  _________________ 1979 porsche 924 Na
924 turbo
Joined: 02 Nov 2002 Posts: 1566 Location: Simi Valley, CA, USA
Posted: Mon May 21, 2007 4:33 am Post subject: |
| Rasta Monsta wrote: | | bruce76-924 wrote: | | It didn't use the same head as any production 944 and likewise Porsche didn't build a 16 valve turbo 944. |
944 Turbo S? |
Not 16v. Even the 968 Turbo S/RS used the 8v head. _________________ Jon Furst |
bruce76-924
Posted: Mon May 21, 2007 4:57 am Post subject: |
Best of all, at 1.1 bar of boost ( for endurance racing ) they put out a quoted 420 bhp, but could have the boost wound up to 1.5 bar and produce 500 bhp. Kind of beats the average production 951!
Cheers, Bruce. _________________ 1976 924 LHD, full cage, semi tube chassis, 951 brakes, lightweight 951 body panels.
Raceboy
Posted: Mon May 21, 2007 5:38 am Post subject: |
Since it's a bit OT, but.....GTP spec engine would yield 500-550 hp @ 1-1.2 bar with Garrett GT35R that I'm going to use. It will be a killer combo: generously flowing head compared to modern ball-bearing and fast-spooling turbo.
I already have all the parts needed (2.5 block, 951 pistons, S head, new stainless valves, seals, bearings, turbo etc) sans clutch. I'll use S2 flywheel (60-2 tooth ring) not 951 flywheel and I'll have to find the best 225mm (like 931) clutch available. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Mon May 21, 2007 5:40 am Post subject: |
awesome _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
dpw928
Posted: Mon May 21, 2007 6:35 am Post subject: |
| Raceboy wrote: | | I'll use S2 flywheel (60-2 tooth ring) not 951 flywheel and I'll have to find the best 225mm (like 931) clutch available. |
Don't know how it would fit but the high HP 928 racers are going back to the early 928 twin disc clutch setup.
78 928 5 sp Silver
bruce76-924
Posted: Mon May 21, 2007 7:57 am Post subject: |
Raceboy,
If you can build it ( and I'm pretty sure you can), then we can let you call a GTP!!! After all, I read that the P in GTP refered to prototype and I guess your motor would fit that description..... good luck with it.
J1NX3D
Joined: 06 Feb 2003 Posts: 1333 Location: New Zealand
Posted: Mon May 21, 2007 10:00 am Post subject: |
| dpw928 wrote: | BTW the engine pictured above appears to be a 944S engine due to the single timing gear. Also, that appears to be a production head, not a one off (or 4 off) developmental head.
Dennis |
yes thats right. people are confusing the 924 gtp ( with the 944 dohc turbo engine) and the 944 gtp ( with the S or S2 engine, i cant remember which.) _________________ '86 944 |
Posted: Mon May 21, 2007 6:24 pm Post subject: |
no, the picture that i posted is indeed a 944 dohc engine and i've only re-posted the picture because paul's post did not show the picture.
As i know the GTP has indeed a DOHC engine i've seen that picture and i had others with close-ups on that engine but i lost them. _________________ Supercharger and EFI kits
https://www.the924.com |
J1NX3D
Raceboy
Posted: Tue May 22, 2007 3:58 pm Post subject: |
924 GTP is NOT 944 Turbo engined! This was a prototype 16valve turbo engine and none of the 924/944/968 turbocharged engines were released with 16valve heads. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
