SpiNko Guest
Posted: Sat May 18, 2002 5:40 am Post subject: |
So, I need a new fuel pump. Any suggestions on what I should do?
My car is the 78 non turbo, with an external pump.
Thanx in advance. |
ltgland Guest
Posted: Sat May 18, 2002 5:51 am Post subject: |
check out the tech/fag/parts in 924.org.
Their Pierburg replacement is cheaper than the Bosch. I need to replace my pump and will get the Pierburg |
Posted: Sat May 18, 2002 10:29 pm Post subject: |
Here's the direct link with info. The Pierburg unit, from what I've seen, will replace all external 924 and 931 pumps:
http://www.924.org/techsection/3fuel.htm#7 Fuel Delivery
Lizard Guest
Posted: Sun May 19, 2002 5:45 am Post subject: |
i am in b.c. canada in chilliwack and i have a 1980 924 porsche that has a working pump on it that you can buy for $10 cdn
if interested just call me (604)807-4523 |
SpiNko Guest
Posted: Mon May 20, 2002 6:08 am Post subject: |
GREAT!
Will be calling soon.
Lizard Guest
Posted: Mon May 20, 2002 6:43 am Post subject: |
| ok call and make arrangments but i work 5:00am - 2:00pm with wednesday thursday off |
silveroldie Guest
Posted: Sat May 25, 2002 10:33 am Post subject: |
| any pump which puts out 50 or so psi with the right capacity will work. I got a replacement off of a VW which works fine but I could have used a RV water pump. Needless to say, I am not a "purist" who insists on genuine Porsche parts. I just want my vehicle to run. |
coconutcowboy Guest
Posted: Wed May 29, 2002 9:49 am Post subject: |
What model of vw pump would you use. a 924 only needs 50 or so psi at the inlet if I am correct.
coconutcowboy Guest
Posted: Wed May 29, 2002 9:50 am Post subject: |
see my other projects under engine mods.
Warped Guest
Posted: Thu May 30, 2002 10:03 am Post subject: |
By the way I just ordered a Pierburg Pump, and they are currently out. They have to back order it (2-3 weeks for them to get it, then 1 more to get to you) They told me to expect at least a month turn around.
By the way for those of you following my little story of getting my car running. I finally got my Bosch fuel pump to work (At least turn on...), but I have decided to go with a quieter pump...plus, they only wanted $135 for it!!!
Warped
[ This Message was edited by: Warped on 2002-05-31 05:02 ] |
8trdrvr Guest
Posted: Thu May 30, 2002 11:29 am Post subject: |
not having much experiance with these cars (yet) is it normal for that rear fuel pump to be REALLY noisy?? mine is... sokay?????
Kev
