cv joints
Roger Hall
PostPosted: Sat Mar 16, 2002 12:48 pm    Post subject: Reply with quote
what size are the 12 point bolts on the cv joints
PostPosted: Sat Mar 16, 2002 2:41 pm    Post subject: Reply with quote
thread- M8x1.25
length- 48mm
strength rating- 12.9
[ This Message was edited by: Smoothie on 2002-03-17 06:03 ]
jl924t
PostPosted: Sat Mar 16, 2002 2:49 pm    Post subject: Reply with quote
8mm
Roger Hall
PostPosted: Sun Mar 17, 2002 8:20 am    Post subject: Reply with quote
thanks
numbers
PostPosted: Tue Mar 19, 2002 7:04 am    Post subject: Reply with quote
Just for info. You do not need to use the twelve point bolts. Standard hex head bolts work just fine. About half of mine were hex head when I got the car, and I have had no problem with them in 16 years.
wdb
PostPosted: Tue Mar 19, 2002 8:55 am    Post subject: Reply with quote
if you replace the cv bolts, make sure the ones you buy are the proper hardness, and strenght. bolts have a torque rating .
