Roger Hall Guest
Posted: Sat Mar 16, 2002 12:48 pm Post subject: |
| what size are the 12 point bolts on the cv joints |
Smoothie Guest
Posted: Sat Mar 16, 2002 2:41 pm Post subject: |
thread- M8x1.25
length- 48mm
strength rating- 12.9
[ This Message was edited by: Smoothie on 2002-03-17 06:03 ] |
jl924t Guest
Posted: Sat Mar 16, 2002 2:49 pm Post subject: |
| 8mm |
Roger Hall Guest
Posted: Sun Mar 17, 2002 8:20 am Post subject: |
| thanks |
numbers Guest
Posted: Tue Mar 19, 2002 7:04 am Post subject: |
| Just for info. You do not need to use the twelve point bolts. Standard hex head bolts work just fine. About half of mine were hex head when I got the car, and I have had no problem with them in 16 years. |
wdb Guest
Posted: Tue Mar 19, 2002 8:55 am Post subject: |
| if you replace the cv bolts, make sure the ones you buy are the proper hardness, and strenght. bolts have a torque rating . |
