Nzl924
Posted: Mon Jan 20, 2025 8:31 am Post subject: TDC |
Hi,
Trying to fit a new cambelt to my 924 (engine is out and belt was off when I got the enginet) and want to confirm the cam and crank are correctly positioned at TDC. If I line the crank to the mark on the pulley, what is the best way to determine if the cam is at TDC?
Thanks |
copeina
Joined: 06 Dec 2023 Posts: 21 Location: Calgary, AB, Canada
Posted: Tue Jan 21, 2025 12:54 am Post subject: |
There is a similar mark on the cam as well. When both are on their marks, things are where they should be.
Hope that helps,
/K _________________ 1978 924 NA Project |
Posted: Tue Jan 21, 2025 2:57 am Post subject: |
Note that the mark on the cam gear is on the back (windshield) side of it. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
fiskolja
Posted: Wed Jan 22, 2025 1:42 am Post subject: |
Is it possible for the mark on the cam gear to be out of sync, as in the gear having rotated independently of the camshaft?
Is there any way to verify that the gear is in sync with the shaft? _________________ 924 NA 1977 |
scm924s
Joined: 22 Oct 2010 Posts: 296 Location: Gloucester UK
Posted: Wed Jan 22, 2025 2:45 am Post subject: |
cam pulley is on locating key, can't be misaligned. You need to get No1 cylinder at top dead centre on compression stroke and TDC on the flywheel
Follow the setting up on here:-
https://members.tripod.com/darrin_smith/porsche/924cam.html _________________ 1984 n/a Ruby Red Metallic
1988 924S Guards red- sold
1986 924S Guards Red - sold
1984 n/a Black - sold
1980 n/a Le Mans#1 - sold
1980 n/a Le Mans#2- sold
1977 Martini - sold |
fiskolja
Posted: Wed Jan 22, 2025 4:29 am Post subject: |
Ah thanks!
I decided, for some reason, to adjust the camgear itself for it to line up after waterpump replacement and it felt like it slipped from the shaft. But I haven't had problems since so that explains why _________________ 924 NA 1977 |
