mmou
Posted: Fri Sep 22, 2023 3:34 pm Post subject: Popup headlights issues. |
Hey guys,
I recently got a 1978 924 and I'm having issues with the headlights not popping up. I'm guessing its to do with the molex connector since the last owner did some unspeakable things to it. If i manually move the knob for the headlight motor the motor will eventually kick in and open/close the headlight regardless of the light setting on/off too.
There's only 3 wires being, red-blue, grey, brown. Grey is the only wire giving a 12v signal when on. Any ideas? Im going to snip this connector but im not sure of the correct sequence.
https://imgur.com/ihVxtuy |
!tom
Posted: Sat Sep 23, 2023 3:06 am Post subject: |
Could also be the relay _________________ 78 924 NA
5-lug |
mmou
Posted: Sat Sep 23, 2023 6:08 am Post subject: |
| !tom wrote: | | Could also be the relay |
I got a new relay as well  |
!tom
Posted: Sat Sep 23, 2023 10:45 am Post subject: |
By relay, that includes the relay socket and connections to the relay. I know sometimes I fix problems with my lights by pulling out and installing the relay which wipes corrosion off the contacts. _________________ 78 924 NA
5-lug |
Mclaren924
Joined: 13 Oct 2021 Posts: 260 Location: Oceanside CA
Posted: Sat Sep 23, 2023 11:48 am Post subject: Re: Popup headlights issues. |
| mmou wrote: | Hey guys,
Those molex connectors are almost always burnt up, broken, or molested. Out of 5 924's I've had, only one was in good condition. _________________ 1980 931 "Salt" Bucket wannabe racer (Dreaming)
1979 3/5 gt clone 924- Shop Test Car |
mmou
Posted: Sun Sep 24, 2023 12:43 am Post subject: |
| You guys know the correct order for the molex cable? |
