Popup headlights issues.
mmou
PostPosted: Fri Sep 22, 2023 3:34 pm    Post subject: Popup headlights issues. Reply with quote
Hey guys,
I recently got a 1978 924 and I'm having issues with the headlights not popping up. I'm guessing its to do with the molex connector since the last owner did some unspeakable things to it. If i manually move the knob for the headlight motor the motor will eventually kick in and open/close the headlight regardless of the light setting on/off too.
There's only 3 wires being, red-blue, grey, brown. Grey is the only wire giving a 12v signal when on. Any ideas? Im going to snip this connector but im not sure of the correct sequence.
https://imgur.com/ihVxtuy
!tom
PostPosted: Sat Sep 23, 2023 3:06 am    Post subject: Reply with quote
Could also be the relay
78 924 NA
5-lug
mmou
PostPosted: Sat Sep 23, 2023 6:08 am    Post subject: Reply with quote
I got a new relay as well
!tom
PostPosted: Sat Sep 23, 2023 10:45 am    Post subject: Reply with quote
By relay, that includes the relay socket and connections to the relay. I know sometimes I fix problems with my lights by pulling out and installing the relay which wipes corrosion off the contacts.
78 924 NA
5-lug
Mclaren924
PostPosted: Sat Sep 23, 2023 11:48 am    Post subject: Re: Popup headlights issues. Reply with quote
mmou wrote:
Hey guys,
Those molex connectors are almost always burnt up, broken, or molested. Out of 5 924's I've had, only one was in good condition.
mmou
PostPosted: Sun Sep 24, 2023 12:43 am    Post subject: Reply with quote
You guys know the correct order for the molex cable?
