Joined: 23 Jul 2007 Posts: 1081 Location: The Netherlands
Posted: Tue Aug 30, 2011 5:50 pm Post subject: Custom manifold for 951 intercooler |
I am going to mount a 951 intercooler on my 931 (with cis).
What will be better, cut an original manifold an modifie it or build a new manifold ?
I used the search but I can only find custom manifolds for EFI/951 intercooler combination. _________________ 937 trackday car
Posted: Tue Aug 30, 2011 7:14 pm Post subject: |
build a new one. _________________ Supercharger and EFI kits
https://www.the924.com |
Shurick
Posted: Wed Aug 31, 2011 12:14 am Post subject: |
Or this one with stock inlet manifold http://picasaweb.google.com/111470514161382354517/Intercooled931InNZ?gsessionid=prwLNFSQvZYPqc5CoFQleA
Consensus is that a custom intake manifold will work best if you want to shorten/improve the line between the 951 FMIC and cylinders _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Wed Aug 31, 2011 12:53 am Post subject: |
Flosho's custom built approach (from this thread):
-nick's modified / customized approach (from this thread):
My modified / customized approach (from this thread):
There are several others documented here on the forum, which you should be able to dig up with some searching... _________________ erstwhile owner of just about every 924 variant ever made |
WEASEL149
Posted: Thu Sep 01, 2011 4:16 am Post subject: |
I like all those approaches.
I do fancy having a go at making one like Ideola's with a spare manifold I have. _________________ 1979 UK 932 |
Posted: Fri Sep 02, 2011 1:24 am Post subject: |
3 fabbers competing ! awesome now who wants some leverage to say which is best.  _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Fri Sep 02, 2011 5:45 am Post subject: |
| WEASEL149 wrote: | I like all those approaches.
I do fancy having a go at making one like Ideola's with a spare manifold I have. |
+1
I have a man lined up already to do this.
Dan, any feedback on this set up? _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Fri Sep 02, 2011 5:49 am Post subject: |
Sadly, it's not in use yet, as the Ultra Wide Body project is on the back burner until I complete the Club Sport. But it was fairly easy for my welder to fabricate, and I'm very optimistic about how it will function. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Fri Sep 02, 2011 12:26 pm Post subject: |
I also like the ideola manifold. . .might move the add-on portion up flush, though. _________________ Toofah King Bad
Posted: Sat Sep 03, 2011 5:23 am Post subject: |
This one also looks nice and I think the used a stock manaifold, but it is hard to see.
Last edited by Dutch924-racer on Sat Sep 03, 2011 5:40 am; edited 1 time in total |
Posted: Sat Sep 03, 2011 5:31 am Post subject: |
| Rasta Monsta wrote: | | I also like the ideola manifold. . .might move the add-on portion up flush, though. |
If you do that, you'll have to rotate the throttle body 90 degrees and mount it sideways, along with fabbing up a custom throttle body bracket & assembly. With the TB so far forward, the diffuser plenum has to be down on the side of the manifold to avoid interfering with the closed hood, which is much lower that far forward than where the main plenum sits. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed Sep 07, 2011 4:07 am Post subject: |
If anyone wants to pay for it, I'll certainly have my manifold flow tested...
Otherwise I'm going to wing it - sorta. _________________ [This Space For Rent] |
Posted: Fri Sep 09, 2011 3:26 am Post subject: |
I also like this one:
MillsMotorsport
Joined: 05 Nov 2011 Posts: 28 Location: Melbourne, Australia
Posted: Wed Nov 30, 2011 9:04 am Post subject: |
| Has anyone tried a modified Audi/VW 1.8T inlet manifold and the cyl head flange plate from the 931? I guess the question is, how far apart are inlet ports on both engines? Are they close? Do they line up? |
