I crashed
924turborox
PostPosted: Sun Oct 02, 2011 6:09 am    Post subject: I crashed Reply with quote
I was turning a 90 left and I started to understeer on a cold, slightly damp road. I added positive lock, then the rear came out and my rear right wheel hit the curb; it's punched into the wheel well and not scrubbing please help me.
Thanks again
Richard
1980 porsche 924 turbo 5speed getrag gearbox
924turborox
PostPosted: Sun Oct 02, 2011 6:10 am    Post subject: Reply with quote
90 degree left going about 15 mph aka I just got into 2nd
Slam
PostPosted: Sun Oct 02, 2011 7:43 am    Post subject: Reply with quote
What kind of help are you looking for? You'll need to replace everything from the tranny out to the wheel and then get an alignment. I'm sure there are lots of good used rear control arms floating about and the job isn't that hard.
Sorry to hear this. With winter coming, driving becomes more of a challenge.
'84 944 - kid blew motor
'80 924 - gone
'78 924 - gone
'77 924 - rusting comfortably
PostPosted: Sun Oct 02, 2011 11:07 am    Post subject: Reply with quote
Four lug or five lug? I may have most or all of the spare parts you'll need.
924turborox
PostPosted: Fri Nov 11, 2011 5:48 pm    Post subject: Reply with quote
If replacing the control arm and a few other parts is the quicker option, that's all I have time for lately I've no idea how to redo bearings and rebuild calipers.
I can't seem to find any new/oem/used rear control arms online...strangly.
Can someone recommend a good site? (ideola?)
or the part number?
Thanks 924 community
PostPosted: Fri Nov 11, 2011 11:10 pm    Post subject: Reply with quote
Do you have a Haynes manual?
And then there's this in our own How-To section:
Replace front wheel bearings
I have 5-lug caliper repair kits listed on my website:
http://garage.ideola.com/prod-Kits.html
I have a set of both 4-lug and 5-lug rear trailing arms. If you're not going to do a complete five lug conversion, then you should keep it simple and replace just the bent 4-lug control arm.
PostPosted: Fri Nov 11, 2011 11:30 pm    Post subject: Reply with quote
OK, you do now understand that positive steering lock is not the right way to deal with understeer?
I would expect, based on my experience hitting and getting hit, you have a bent rim and trailing arm. Agreed, it's not that bad of a deal - but you will need to get it properly aligned (toe and camber), and it does require some large metric sockets/wrenches to swap (24 and 19mm).
924turborox
PostPosted: Sun Nov 13, 2011 7:00 pm    Post subject: Reply with quote
As far as I've found, the part number is 477501036D for the RIGHT rear control arm/trailing arm. I don't know if:
http://www.paragon-products.com/ProductDetails.asp?ProductCode=PP171%2E407%2E153D&CartID=1
is the right part one. I'm sorry to be so naive/slow about this, but I'm between school and being broke.
PostPosted: Sun Nov 13, 2011 11:58 pm    Post subject: Reply with quote
That's the right front one, except it doesn't have the mounting tabs for the swaybar... one taken from an actual 924 (non-S) will have 'em...
