Posted: Thu Jan 29, 2009 12:47 pm Post subject: Coolant transfer tube replacement |
Im replacing my coolant transfer tube with some thin walled aluminium tubing..any suggestions on size?
i have the following three options..
1-Top 2- bottom left 3- bottom right
also did people who have done this weld a "lip" around the edge to help with clamps gripping the rubber hose?
Aluminium tube is quite thin...say 2mm is there any problem with this? the transfer tube itself is quite thin but i think its a harder alloy _________________ 1979 NA
my Porsches Arse!!! |
macBdog
Joined: 16 Aug 2004 Posts: 1111 Location: Brisbane, Australia
Posted: Thu Jan 29, 2009 12:57 pm Post subject: |
The lip is done by using a bead roller. It would take 2 seconds once you find someone with one. _________________ 1979 931 with a 350 chev
1973 911E with EFI
| p-talk wrote: | I'm still convinced the word 'Porsche' makes people crazy in all kinds of ways  |
Posted: Thu Jan 29, 2009 1:00 pm Post subject: |
| macBdog wrote: | | The lip is done by using a bead roller. It would take 2 seconds once you find someone with one. |
any particular pipe size tickle your fancy macb? _________________ 1979 NA
Posted: Thu Jan 29, 2009 9:15 pm Post subject: Re: Coolant transfer tube replacement |
| Scorpio wrote: | | Im replacing my coolant transfer tube |
Why?
69 911 |
Posted: Thu Jan 29, 2009 10:12 pm Post subject: Re: Coolant transfer tube replacement |
| pocketscience wrote: | | Scorpio wrote: | | Im replacing my coolant transfer tube |
Why?
G. |
coz theres a whole from the top welded on tube to the main bottom tube when it should be blank....and coz macb and leadfoot say so i.e better coolant flow _________________ 1979 NA
