Coolant transfer tube replacement
PostPosted: Thu Jan 29, 2009 12:47 pm    Post subject: Coolant transfer tube replacement Reply with quote
Im replacing my coolant transfer tube with some thin walled aluminium tubing..any suggestions on size?
i have the following three options..
1-Top 2- bottom left 3- bottom right
also did people who have done this weld a "lip" around the edge to help with clamps gripping the rubber hose?
Aluminium tube is quite thin...say 2mm is there any problem with this? the transfer tube itself is quite thin but i think its a harder alloy
1979 NA
my Porsches Arse!!!
macBdog
PostPosted: Thu Jan 29, 2009 12:57 pm    Post subject: Reply with quote
The lip is done by using a bead roller. It would take 2 seconds once you find someone with one.
1979 931 with a 350 chev
1973 911E with EFI
p-talk wrote:
PostPosted: Thu Jan 29, 2009 1:00 pm    Post subject: Reply with quote
any particular pipe size tickle your fancy macb?
1979 NA
my Porsches Arse!!!
PostPosted: Thu Jan 29, 2009 9:15 pm    Post subject: Re: Coolant transfer tube replacement Reply with quote
Why?
PostPosted: Thu Jan 29, 2009 10:12 pm    Post subject: Re: Coolant transfer tube replacement Reply with quote
pocketscience wrote:
Why?
coz theres a whole from the top welded on tube to the main bottom tube when it should be blank....and coz macb and leadfoot say so i.e better coolant flow
1979 NA
my Porsches Arse!!!
PostPosted: Thu Jan 29, 2009 10:31 pm    Post subject: Re: Coolant transfer tube replacement Reply with quote
Why?
http://www.924board.org/viewtopic.php?p=194258#194258
