ourkid
Joined: 04 Aug 2008 Posts: 84 Location: Ellesmere Port,Cheshire UK
Posted: Wed Oct 01, 2008 2:45 am Post subject: Location of fuel sender earth? |
I'm sure i've seen this before but can't bring it up on a search.My gauge has started bouncing at quarter full,I'm checking the spades on top,but where does the earth lead connect to ground? _________________ 1983 924 N/A |
2Fast
Joined: 09 Dec 2007 Posts: 459 Location: Klamath Falls, OR
Posted: Wed Oct 01, 2008 4:45 am Post subject: |
Mine does this also, recently I removed my Fuel Sender and cleaned up stuff. Sadly no results...But anyways, I would think the ground (earth) would be near the left taillight. _________________ =====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd |
ourkid
Posted: Wed Oct 01, 2008 6:17 am Post subject: |
I've just tried to trace it back from the top of the sender.It passes between top of tank and boot floor but i can't see the other end underneath or at the back anywhere?
Incidentaly,what is the capacity of the tank?.After cleaning up the terminals on the sender i now get a steady quarter tank but i've just put 20 litres in?
Oh,it's a new sender...
Ade. _________________ 1983 924 N/A |
JackRabbit
Joined: 11 Aug 2008 Posts: 147 Location: Clarion, Pennsylvania
Posted: Wed Oct 01, 2008 7:36 am Post subject: |
16.4 gallons... you can translate that to liters if you like. _________________ '79 Porsche 924
'05 Honda Civic
'07 BMW K1200R
'78 Honda Express
'52 Willy's
'58 Wheel Horse |
ourkid
Posted: Thu Oct 02, 2008 3:07 am Post subject: |
Still can't find where the ground connects at the other end.....
Anyone?  _________________ 1983 924 N/A |
Posted: Thu Oct 02, 2008 3:19 am Post subject: |
The grounds for the fuel sender end up in the rear-of-car harness, and are terminated at the grounding point between the tail lights. _________________ erstwhile owner of just about every 924 variant ever made |
ourkid
Posted: Thu Oct 02, 2008 4:06 am Post subject: |
Thanks Ideola,
It was sosking wet around there,probably from some damage to my hatch seal.I now also have a hatch release that works properly!
