Location of fuel sender earth?
ourkid
PostPosted: Wed Oct 01, 2008 2:45 am    Post subject: Location of fuel sender earth? Reply with quote
I'm sure i've seen this before but can't bring it up on a search.My gauge has started bouncing at quarter full,I'm checking the spades on top,but where does the earth lead connect to ground?
1983 924 N/A
2Fast
PostPosted: Wed Oct 01, 2008 4:45 am    Post subject: Reply with quote
Mine does this also, recently I removed my Fuel Sender and cleaned up stuff. Sadly no results...But anyways, I would think the ground (earth) would be near the left taillight.
=====>Alex<=====
1979 Porsche 924 NA 5spd
1979 Parts Porshce 924 NA 5spd
ourkid
PostPosted: Wed Oct 01, 2008 6:17 am    Post subject: Reply with quote
I've just tried to trace it back from the top of the sender.It passes between top of tank and boot floor but i can't see the other end underneath or at the back anywhere?
Incidentaly,what is the capacity of the tank?.After cleaning up the terminals on the sender i now get a steady quarter tank but i've just put 20 litres in?
Oh,it's a new sender...
Ade.
1983 924 N/A
JackRabbit
PostPosted: Wed Oct 01, 2008 7:36 am    Post subject: Reply with quote
16.4 gallons... you can translate that to liters if you like.
'79 Porsche 924
'05 Honda Civic
'07 BMW K1200R
'78 Honda Express
'52 Willy's
'58 Wheel Horse
ourkid
PostPosted: Thu Oct 02, 2008 3:07 am    Post subject: Reply with quote
Still can't find where the ground connects at the other end.....
Anyone?
1983 924 N/A
PostPosted: Thu Oct 02, 2008 3:19 am    Post subject: Reply with quote
The grounds for the fuel sender end up in the rear-of-car harness, and are terminated at the grounding point between the tail lights.
ourkid
PostPosted: Thu Oct 02, 2008 4:06 am    Post subject: Reply with quote
Thanks Ideola,
It was sosking wet around there,probably from some damage to my hatch seal.I now also have a hatch release that works properly!
Ade.
1983 924 N/A
