Oil return line bung for turbo
PostPosted: Tue Nov 25, 2008 12:54 pm    Post subject: Oil return line bung for turbo Reply with quote
Is the alloy sump sufficiently thick/strong enough to use a bolt in bung with gasket...dont want to have to get one welded on
Also whats a good height to have the bung at? i know lower than the turbo so it flows down freely yet higher than the highest oil level(taking into account slope of vehicle)..does that cover it?
1979 NA
my Porsches Arse!!!
PostPosted: Tue Nov 25, 2008 1:02 pm    Post subject: Reply with quote
I think you just like saying "bung."
PostPosted: Tue Nov 25, 2008 1:11 pm    Post subject: Reply with quote
1979 NA
my Porsches Arse!!!
PostPosted: Tue Nov 25, 2008 2:02 pm    Post subject: Reply with quote
I believe Bob Dodd used to have a copy of the BAE manual, you might consider contacting him as it shows where they drilled/tapped the oil pan for the drain line.
FYI the pan is plenty thick as I tapped it for an oil air separator return line.
The secondary oil plug (top plug) is about 1" below the oil level IIRC
Stu.
PostPosted: Tue Nov 25, 2008 2:43 pm    Post subject: Reply with quote
Thanks Stu... The only thing im using from the BAE kit is the manifold... i bought a garrett T25 to use instead of the Rajay
1979 NA
my Porsches Arse!!!
Min
PostPosted: Tue Nov 25, 2008 3:09 pm    Post subject: Re: Oil return line bung for turbo Reply with quote
Just has to be higher than the oil level. Personally I'd mount it as high up on the pan as you can without interfering with anything.
Min
PostPosted: Wed Nov 26, 2008 8:11 pm    Post subject: Reply with quote
this section is the thicker part, see if you flange fits up here...
you might need to run over the top of the torque tube, not sure what's the best route.
PostPosted: Thu Nov 27, 2008 10:39 am    Post subject: Reply with quote
hey stu i think ill be plumbing the front side of the oil pan near where the turbo sits...isnt that point in the piccy a little too low?
1979 NA
my Porsches Arse!!!
Andrew NZ
PostPosted: Thu Nov 27, 2008 1:57 pm    Post subject: Reply with quote
Mine was a screw in one, and it always leaked so I had to patch it with heaps of metal putty. Get one welded on while you've got it apart and be done with it! You won't regret it later. I'll look at my old sump over the weekend and let you know where the drain went in.
Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz
PostPosted: Fri Nov 28, 2008 10:59 am    Post subject: Reply with quote
hey andrew heres a pic of your engine after you rebuilt it
looks like your return is just under the crankshast pulley at the front
1979 NA
my Porsches Arse!!!
Andrew NZ
PostPosted: Fri Nov 28, 2008 2:32 pm    Post subject: Reply with quote
Yep, that's it!
Andrew
1977 RX924 race car
vemser
PostPosted: Mon Jan 12, 2009 2:16 am    Post subject: Reply with quote
What about best place for water cooling lines connection? I thinking about steel tube from pump to head back side.
