Posted: Tue Nov 25, 2008 12:54 pm Post subject: Oil return line bung for turbo |
Is the alloy sump sufficiently thick/strong enough to use a bolt in bung with gasket...dont want to have to get one welded on
Also whats a good height to have the bung at? i know lower than the turbo so it flows down freely yet higher than the highest oil level(taking into account slope of vehicle)..does that cover it? _________________ 1979 NA
my Porsches Arse!!! |
Posted: Tue Nov 25, 2008 1:02 pm Post subject: |
I think you just like saying "bung." _________________ Toofah King Bad
Posted: Tue Nov 25, 2008 1:11 pm Post subject: |
| Quote: |
I think you just like saying "bung." |
Posted: Tue Nov 25, 2008 2:02 pm Post subject: |
I believe Bob Dodd used to have a copy of the BAE manual, you might consider contacting him as it shows where they drilled/tapped the oil pan for the drain line.
FYI the pan is plenty thick as I tapped it for an oil air separator return line.
The secondary oil plug (top plug) is about 1" below the oil level IIRC
Stu. _________________ 1981 ROW 924 Turbo -
Posted: Tue Nov 25, 2008 2:43 pm Post subject: |
| Quote: | I believe Bob Dodd used to have a copy of the BAE manual, you might consider contacting him as it shows where they drilled/tapped the oil pan for the drain line.
The secondary oil plug (top plug) is about 1" below the oil level IIRC |
Thanks Stu... The only thing im using from the BAE kit is the manifold... i bought a garrett T25 to use instead of the Rajay _________________ 1979 NA
Min
Posted: Tue Nov 25, 2008 3:09 pm Post subject: Re: Oil return line bung for turbo |
| Scorpio wrote: | | Also whats a good height to have the bung at? i know lower than the turbo so it flows down freely yet higher than the highest oil level(taking into account slope of vehicle)..does that cover it? |
Just has to be higher than the oil level. Personally I'd mount it as high up on the pan as you can without interfering with anything.
Posted: Wed Nov 26, 2008 8:11 pm Post subject: |
this section is the thicker part, see if you flange fits up here...
you might need to run over the top of the torque tube, not sure what's the best route.
Posted: Thu Nov 27, 2008 10:39 am Post subject: |
hey stu i think ill be plumbing the front side of the oil pan near where the turbo sits...isnt that point in the piccy a little too low? _________________ 1979 NA
Andrew NZ
Posted: Thu Nov 27, 2008 1:57 pm Post subject: |
Mine was a screw in one, and it always leaked so I had to patch it with heaps of metal putty. Get one welded on while you've got it apart and be done with it! You won't regret it later. I'll look at my old sump over the weekend and let you know where the drain went in. _________________ Andrew
1977 RX924 race car
12a bridgeport supercharged
www.race4-dcup.co.nz |
Posted: Fri Nov 28, 2008 10:59 am Post subject: |
hey andrew heres a pic of your engine after you rebuilt it
looks like your return is just under the crankshast pulley at the front
Andrew NZ
Posted: Fri Nov 28, 2008 2:32 pm Post subject: |
Yep, that's it! _________________ Andrew
1977 RX924 race car
vemser
Joined: 06 May 2008 Posts: 46 Location: Russia, Moscow
Posted: Mon Jan 12, 2009 2:16 am Post subject: |
| What about best place for water cooling lines connection? I thinking about steel tube from pump to head back side. |
