CorsePerVita
Joined: 25 Jul 2008 Posts: 1992 Location: Redmond, Oregon
Posted: Mon May 10, 2010 6:20 pm Post subject: Crower rods - worth it? |
Curious. Buying goodies for the engine rebuild. Crower rods - worth it over stock?
Will also be doing some head work, and eventually when i can get my ass up to portland buy stefan's ms system he has. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS |
Posted: Mon May 10, 2010 7:43 pm Post subject: |
Depends on your goals. I dont know much about crower rods but theres huge weight saves that can be done with some nice forged ones. Nice if you want high power and high revs. _________________ 1980 924 Turbo
Posted: Mon May 10, 2010 9:26 pm Post subject: |
When you factor in the cost of new rod bolts (~$245) and having to have custom bushes made ($???, NLA from Porsche), it's definitely worth thinking about. They are the least expensive aftermarket alternative available for our cars as well (Pauter and Oliver both run ~$1200 a set). Lighter & stronger too. _________________ erstwhile owner of just about every 924 variant ever made |
Martijnus
Posted: Mon May 10, 2010 9:48 pm Post subject: |
I agree with Dan.
I've found out those bushings aren't available anymore and they'll need machining anyways, so that'll cost more too.
If the old ones are good and you're not trying to go extreme though... just use the old ones... depending on their state. _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
Posted: Tue May 11, 2010 2:41 am Post subject: |
If you can hack it I would go with the lighter Crower units. Less stress on everything with lighter parts. +1 on the bolts too. No longer have to worry about that issue (bolts come with rods)
From a wisdom perspective (many engines built). Its normally a good a idea to build a good strong bottom end. Then when you want more later your short block is ready for you  _________________ 1980 931 since 1989
Posted: Tue May 11, 2010 2:47 am Post subject: |
How about a piccie...
...and a shameless plug  _________________ erstwhile owner of just about every 924 variant ever made |
CorsePerVita
Posted: Tue May 11, 2010 4:52 am Post subject: |
well, i have been saving my pennies and do want a pretty serious build. i'm obviously not going to build it till it's ready to burst, however, i do want a nice engine.
sounds like they're worth it then. i shall wait a few and then order. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
Posted: Tue May 11, 2010 5:04 am Post subject: |
The rods I purchased for the UWB are going into the club sport motor, so I now need to order another set for the UWB. I can hold off on that until you're ready to order yours, as I'm in no huge rush at this point... _________________ erstwhile owner of just about every 924 variant ever made |
CorsePerVita
Posted: Tue May 11, 2010 5:38 am Post subject: |
Dan, do the rods come with bolts on those or do i still need the ARP bolts? And if they do come with bolts, are they REUSABLE? If they come with the bolts that would save a nice penny.
It looks like they do but I want to make sure. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
CorsePerVita
Posted: Tue May 11, 2010 6:13 am Post subject: |
called crower, they said yes. if you need to order them order them dan, i may actually end up just doing the bolts and stuff and doing a basic rebuild this time around, not entirely sure. i do definitely wanna build the engine but may give it a go with basic stuff this time around.
He said they are NOT reusable bolts. They are stretchables, but he said you can get 4-5 uses out of them easily. _________________ - 1977 Porsche 924 2.0 N/A (Trackday Project)
Posted: Tue May 11, 2010 6:53 am Post subject: |
Yes, bolts & nuts come with the rods, and they include "integral" bushes for the little end. If you order independently, make sure you specify that Crower notch the big end to replace the function of the stock rods' integral sprayers, as these do not have the integral style.
As I said, I'm in no huge hurry at this point. When I'm ready to order mine, I'll drop you an email. _________________ erstwhile owner of just about every 924 variant ever made |
Min
Posted: Wed May 12, 2010 4:53 am Post subject: |
For my curiosity, do you know what manufacturing process was used to create these rods? are they machined from billet or forged then machined?
Posted: Wed May 12, 2010 5:10 am Post subject: |
Steel billet, CNC machined, heat-treated, and shot-peened. The also offer Titanium. _________________ erstwhile owner of just about every 924 variant ever made |
Martijnus
Posted: Thu May 13, 2010 2:21 am Post subject: |
I don't like these threads...
They tend to cost me money  _________________ "Rule: Turbo's make torque, and torque makes fun." (C. Bell)
Posted: Thu May 13, 2010 2:34 am Post subject: |
Don't lose too much sleep over it, man. Toofah rods are quite strong. _________________ Toofah King Bad
