Crower rods - worth it?
CorsePerVita
PostPosted: Mon May 10, 2010 6:20 pm    Post subject: Crower rods - worth it? Reply with quote
Curious. Buying goodies for the engine rebuild. Crower rods - worth it over stock?
Will also be doing some head work, and eventually when i can get my ass up to portland buy stefan's ms system he has.
- 1977 Porsche 924 2.0 N/A (Trackday Project)
- 1980 Porsche 931 (Daily)
- 1987 Lamborghini Jalpa
- 1999 Ducati 900SS
PostPosted: Mon May 10, 2010 7:43 pm    Post subject: Reply with quote
Depends on your goals. I dont know much about crower rods but theres huge weight saves that can be done with some nice forged ones. Nice if you want high power and high revs.
PostPosted: Mon May 10, 2010 9:26 pm    Post subject: Reply with quote
When you factor in the cost of new rod bolts (~$245) and having to have custom bushes made ($???, NLA from Porsche), it's definitely worth thinking about. They are the least expensive aftermarket alternative available for our cars as well (Pauter and Oliver both run ~$1200 a set). Lighter & stronger too.
Martijnus
PostPosted: Mon May 10, 2010 9:48 pm    Post subject: Reply with quote
I agree with Dan.
I've found out those bushings aren't available anymore and they'll need machining anyways, so that'll cost more too.
If the old ones are good and you're not trying to go extreme though... just use the old ones... depending on their state.
924 "50-jahre", 1981.
MSII/extra, LPG, ITB's, 5lug.
To be turbo'ed in a while.
PostPosted: Tue May 11, 2010 2:41 am    Post subject: Reply with quote
If you can hack it I would go with the lighter Crower units. Less stress on everything with lighter parts. +1 on the bolts too. No longer have to worry about that issue (bolts come with rods)
From a wisdom perspective (many engines built). Its normally a good a idea to build a good strong bottom end. Then when you want more later your short block is ready for you
PostPosted: Tue May 11, 2010 2:47 am    Post subject: Reply with quote
How about a piccie...
...and a shameless plug
CorsePerVita
PostPosted: Tue May 11, 2010 4:52 am    Post subject: Reply with quote
well, i have been saving my pennies and do want a pretty serious build. i'm obviously not going to build it till it's ready to burst, however, i do want a nice engine.
sounds like they're worth it then. i shall wait a few and then order.
- 1999 Ducati 900SS
PostPosted: Tue May 11, 2010 5:04 am    Post subject: Reply with quote
The rods I purchased for the UWB are going into the club sport motor, so I now need to order another set for the UWB. I can hold off on that until you're ready to order yours, as I'm in no huge rush at this point...
CorsePerVita
PostPosted: Tue May 11, 2010 5:38 am    Post subject: Reply with quote
Dan, do the rods come with bolts on those or do i still need the ARP bolts? And if they do come with bolts, are they REUSABLE? If they come with the bolts that would save a nice penny.
It looks like they do but I want to make sure.
- 1999 Ducati 900SS
CorsePerVita
PostPosted: Tue May 11, 2010 6:13 am    Post subject: Reply with quote
called crower, they said yes. if you need to order them order them dan, i may actually end up just doing the bolts and stuff and doing a basic rebuild this time around, not entirely sure. i do definitely wanna build the engine but may give it a go with basic stuff this time around.
He said they are NOT reusable bolts. They are stretchables, but he said you can get 4-5 uses out of them easily.
- 1999 Ducati 900SS
PostPosted: Tue May 11, 2010 6:53 am    Post subject: Reply with quote
Yes, bolts & nuts come with the rods, and they include "integral" bushes for the little end. If you order independently, make sure you specify that Crower notch the big end to replace the function of the stock rods' integral sprayers, as these do not have the integral style.
As I said, I'm in no huge hurry at this point. When I'm ready to order mine, I'll drop you an email.
Min
PostPosted: Wed May 12, 2010 4:53 am    Post subject: Reply with quote
For my curiosity, do you know what manufacturing process was used to create these rods? are they machined from billet or forged then machined?
Min
PostPosted: Wed May 12, 2010 5:10 am    Post subject: Reply with quote
Steel billet, CNC machined, heat-treated, and shot-peened. The also offer Titanium.
Martijnus
PostPosted: Thu May 13, 2010 2:21 am    Post subject: Reply with quote
I don't like these threads...
They tend to cost me money
PostPosted: Thu May 13, 2010 2:34 am    Post subject: Reply with quote
Don't lose too much sleep over it, man. Toofah rods are quite strong.
