924 still turning over after keys are removed!!!
paulsmaroon924
PostPosted: Wed Oct 07, 2009 4:22 am    Post subject: 924 still turning over after keys are removed!!! Reply with quote
The starter is still turning over even after the keys are removed! what could be causing this, also the battery was being drawn so much that it drained in about a minute! and started to smole from the negative terminal lead, the leads on both ends were REALLY hot.
thanks lads
Ozzie
PostPosted: Wed Oct 07, 2009 7:00 am    Post subject: Reply with quote
starter solenoid could be jammed or ign switch is stuffed.
Its AUTO and its BLACK
Montego Black on black/red
paulsmaroon924
PostPosted: Wed Oct 07, 2009 7:24 am    Post subject: Reply with quote
how would i test for either of these please, where is the starter solenoid ?
Ozzie
PostPosted: Wed Oct 07, 2009 12:17 pm    Post subject: Reply with quote
on the starter- you have to remove it and clean it
If you disconnect the ign switch and it still keeps going then its the starter.
PostPosted: Wed Oct 07, 2009 5:20 pm    Post subject: Reply with quote
Why would this be considered a performance upgrade?
paulsmaroon924
PostPosted: Wed Oct 07, 2009 7:19 pm    Post subject: Reply with quote
well it would GREATLY help the performance of the car if it was running and i know the spark would be better from the battery if it wasnt flat therby also aiding performance.
sorry for being facecious, i didnt know where else to list this, its not body or wheels and not general discusion so.... ok cheers for that lads, i have a new starter, my old man is coming sunday to give me a hand with it so ill let you know how that goes.
is removing the ignition an easy job? could i seperate the ignition quickly and easily while it is turning over by itself to see if i can eliminate that?
cheers lads
PostPosted: Wed Oct 07, 2009 8:23 pm    Post subject: Reply with quote
General discussion is the appropriate forum for this type of question and will usually result in more suitable replies.
Reaching behind the dash and pulling the black plug on the ignition switch will isolate it for testing purposes.
