paulsmaroon924
Posted: Wed Oct 07, 2009 4:22 am Post subject: 924 still turning over after keys are removed!!! |
The starter is still turning over even after the keys are removed! what could be causing this, also the battery was being drawn so much that it drained in about a minute! and started to smole from the negative terminal lead, the leads on both ends were REALLY hot.
thanks lads |
Ozzie
Posted: Wed Oct 07, 2009 7:00 am Post subject: |
starter solenoid could be jammed or ign switch is stuffed. _________________ Porsche 924 1984 (UK import) NA
Its AUTO and its BLACK
Montego Black on black/red
paulsmaroon924
Posted: Wed Oct 07, 2009 7:24 am Post subject: |
| how would i test for either of these please, where is the starter solenoid ? |
Ozzie
Posted: Wed Oct 07, 2009 12:17 pm Post subject: |
on the starter- you have to remove it and clean it
If you disconnect the ign switch and it still keeps going then its the starter. _________________ Porsche 924 1984 (UK import) NA
Posted: Wed Oct 07, 2009 5:20 pm Post subject: |
Why would this be considered a performance upgrade?  |
paulsmaroon924
Posted: Wed Oct 07, 2009 7:19 pm Post subject: |
well it would GREATLY help the performance of the car if it was running and i know the spark would be better from the battery if it wasnt flat therby also aiding performance.
sorry for being facecious, i didnt know where else to list this, its not body or wheels and not general discusion so.... ok cheers for that lads, i have a new starter, my old man is coming sunday to give me a hand with it so ill let you know how that goes.
is removing the ignition an easy job? could i seperate the ignition quickly and easily while it is turning over by itself to see if i can eliminate that?
cheers lads |
Posted: Wed Oct 07, 2009 8:23 pm Post subject: |
General discussion is the appropriate forum for this type of question and will usually result in more suitable replies.
| paulsmaroon924 wrote: |
is removing the ignition an easy job? could i seperate the ignition quickly and easily while it is turning over by itself to see if i can eliminate that? |
Reaching behind the dash and pulling the black plug on the ignition switch will isolate it for testing purposes. |
