w.a.
Joined: 27 May 2003 Posts: 19 Location: Danville, Virginia
Posted: Sat Aug 09, 2003 7:45 am Post subject: Oil Pressure Sending Unit |
My mechanic was hooking my engine back up after the rebuild and broke a terminal off of the oil pressure sending unit. No one locally has one. I've got a track event that I need to leave for on Sunday the 17th and lots of other little things to do to get the car ready. Anyone have any idea where I can lay my hands on one ASAP? Are there any other applications/substitutions that will work?
Thanks,
w.a. _________________ '92 968 Coupe, Black/Tan
'76 924 J Stock Racer
"If you are not living life on the edge, you are taking up too much space." |
Joined: 29 Jul 2001 Posts: 9063 Location: Royal Oak, MI, USA
Posted: Sat Aug 09, 2003 8:04 am Post subject: |
Time to start doing it yourself? I'm thinking?
Pardon be for seeming a little dense, but did you try your dealer or best local euro car parts store? They're available in the aftermarket no problem... _________________ Vaughan Scott
w.a.
Posted: Sat Aug 09, 2003 8:08 am Post subject: |
Yes, tried the dealer, even tried the VW dealer. They don't keep them but said they could probably get one. Any recommendations on a parts house that might actually have one in stock?
Best,
mrobbo612
Posted: Sun Aug 10, 2003 11:33 pm Post subject: |
any vdo 10 bar pressure sensor will work the gauge. if the sensor you obtain has 2 terminal connect one to earth. the combination pressure sender,warning light sensor is a little more difficult to come by. 10 bar vdo sensors are available at most instument shops. connect blue with white wire to gauge. if required you can tee off the rear of the head and fit a warning light switch and connect to blue with black wire
cheers |
w.a.
Posted: Mon Aug 11, 2003 12:22 pm Post subject: |
Thanks So much!!! That's exactly the info I was looking for.
Best,
