are camber boxes legal ?
jesse wall
PostPosted: Fri Apr 25, 2003 1:06 pm    Post subject: are camber boxes legal ? Reply with quote
Are rear camber boxes legal in scca or pca or 944 cup ? thanks Jesse
jesse wall 'new driver' , 87 924s
PostPosted: Fri Apr 25, 2003 10:26 pm    Post subject: Reply with quote
What exactly do you mean by a rear camber box?
John Brown
PostPosted: Fri Apr 25, 2003 11:42 pm    Post subject: Reply with quote
Ask Dave about the cup. But I don't think they would be. If they are not OK for SCCA then you can not enter as an ITS car; and if they are not legal for PCA then you can not enter as an PCA H or I car. So, no.
John
jjadczak
PostPosted: Tue Apr 29, 2003 4:49 am    Post subject: Reply with quote
Ditto's, what are you talking about?
jesse wall
PostPosted: Tue Apr 29, 2003 12:31 pm    Post subject: camber box Reply with quote
Where the rear control arm fits into the torsion tube a metal box is placed that allows the camber to be changed by tightening bolt after shims are added , this lets you adjust camber without affecting toe and allows more camber,folks sell them for 911 and 930 looks easy enough to weld one up , I think if you were to slot the holes in the torsion carier making inside hole lower and outside [towards wheel] hole higher you could get more camber , the box allows easy adjustment just crawl under car and have buddy tell you when you have enough camber by adding shims . Found this in fixing der porsche ,guys were getting 931 track ready , wanted to know if anyone has had esperiencebuilding one and if it would be legal , think it would be for pca improved anyway may be too much trouble Jesse
PostPosted: Tue Apr 29, 2003 9:45 pm    Post subject: Reply with quote
One more thing, this might aggravate any attempts to install spherical bearings into the rear trailing arms, at least using the commercially available kits.
