Project-924-1979
Posted: Wed Jan 14, 2026 5:12 am Post subject: Cunifer brakelines for rear controlarms 477611781 477611782 |
Hello everyone!
As some of you might know, most of the brake lines for the 924 are nla, as are the lines on the rear control arms, also known as: 477611781 & 477 611 782. I've made new ones! I make them from cunifer with zinc plated steel fittings. The metarials used should make the brake line last even longer than the original ones because of the good corrosion resistance of cunifer. I can make more brake lines if there is any intrest, so let me know! See pictures below of the final results.
 _________________ Restoring a late 1979 Porsche 924. This is my first car and my first attempt at restoring a car.
Learning a lot along the way and doing as much as I can myself. |
Posted: Wed Jan 14, 2026 10:12 pm Post subject: |
Well done...nice work. _________________ 80/81 932/8 ROW |
Raize
Posted: Fri Jan 16, 2026 7:27 am Post subject: |
Watch out for fake cunifer. I had a coil of pipe sold as "cunifer" but it was magnetic... obviously copper plated steel... not great.
Definitely a good upgrade and one less thing to worry about rusting. |
Project-924-1979
Posted: Fri Jan 16, 2026 3:59 pm Post subject: |
Don't worry, bought it from a reputable company. _________________ Restoring a late 1979 Porsche 924. This is my first car and my first attempt at restoring a car.
