Maximum block decking
Karlio
PostPosted: Fri Nov 14, 2025 6:07 am    Post subject: Maximum block decking Reply with quote
Any thoughts on what the maximum that an N/A block can be decked before it becomes an interference engine?
A previous race engine i done had 0.5mm but i want to go a bit more adventurous
daniel
PostPosted: Fri Nov 14, 2025 5:18 pm    Post subject: Reply with quote
Have you considered a thinner head gasket (cometic)
1989 944 Cabriolet
PostPosted: Fri Nov 14, 2025 6:19 pm    Post subject: Reply with quote
I assume you run some other cam than the orignal one, so I think the only way is to measure what you have clearance wise and go from there.
Karlio
PostPosted: Sat Nov 15, 2025 2:05 am    Post subject: Reply with quote
Yep running a modified Newman cam 290 deg duration with standard lift. Cometic 0.5 fitted as standard on the race car
safe
PostPosted: Mon Nov 17, 2025 1:41 am    Post subject: Reply with quote
1.5 mm is fine. probably 2 also.
Don't get the non interference thing.... 90%of all engines are interference.
/Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe
