barnwerks
Joined: 28 Oct 2022 Posts: 40 Location: Northeast and southeast US
Posted: Fri Dec 27, 2024 7:12 am Post subject: |
[quote="Raize"] | Kenodog wrote: |
It really makes me wonder how we had the early 924 with no in-tank pump, then the later 924 with an in-tank pump, then the 944 with again no in-tank pump?
What changed on the 944 that it could operate with only an external pump? Why did the 924 get an in-tank one in the first place? |
I have come to understand that the in-tank pump was (occasionally) required to eliminate the possibility of cavitation on the suction side of the main pump. This could happen at low fuel (tank) level along with high altitude. This is perhaps something that was learned with the early 924 and the in-tank feed pump was the resolve. The same design exists on the early 928's, interestingly, the 928's were all wired for the in-tank pump but not all cars received the pump, seemingly based on global destination.
The difference in the 924S, 944 and later 928's that eliminates the need for the in-tank pump corresponds with the switch from the CIS K jet to Motronic or L jet fuel injection systems which require much less fuel delivery pressure. |
Raize
Posted: Sun Jan 19, 2025 7:51 pm Post subject: |
I guess one other issue with the in-tank pump is if it stops working, you end up with a pretty big restriction in front of the main pump.
I found data on the main pump that I'm using that says it's rated to 500mm of suction head, it's a Pierburg E3T internal gearotor pump, not sure if the Bosch roller cell pumps would be better or worse at that application. |
wally509
Joined: 06 Dec 2024 Posts: 15 Location: Burlington, WI
Posted: Sat Apr 26, 2025 7:23 am Post subject: Dansk Fuel tank is in the '77 |
Hello,
Wanted to close the loop here. I removed the sending unit to get a better look and there were huge sheets of the POR-15 or Bill Hirsch or Eastwood tank coating floating around in there (I contacted the car's restorer and he could not remember for sure which brand he used). A professional fuel tank restoration shop was not able to get the remaining coating out so they could do their coating process, therefore the original tank was junk.
I purchased the Dansk repro tank 477.201.021 F. In order to use it I also needed the in-tank filter 928.201.081.04, the later sending unit 477.919.051 B and four adhesive rubber pads that go on top of the tank 477.201.295 B. The shop that did the work for me also replaced the breather hose, the overflow hose and the hose to the pump, and said those were just generic bulk fuel hose. This car was not equipped from the factory with the triangular expansion tank so they just ran a longer hose from where the fitting on the newer tank was for that to the filler neck connection for it. They reused the original bellows style connector hose from the new tank to the filler neck, it was compatible with the new tank. _________________ 1977 Martini 924, 1985 Mercedes 300SD, 1956 Austin-Healey 100 |
