Fitting a Late (Plastic) Fuel Tank to a 924S
Goto page Previous  1, 2
PostPosted: Tue Apr 13, 2010 10:53 am    Post subject: Reply with quote
Are you doing this, Paul? Unfortunately, I can't photgraph the return line, but I can probably get a good pic of the custom feed line.
PostPosted: Tue Apr 13, 2010 10:57 am    Post subject: Reply with quote
Just considering my options since the white ghost leaks fuel on the muffler if you fill the tank too full.
PostPosted: Tue Apr 13, 2010 11:00 am    Post subject: Reply with quote
Highly recommended upgrade. Also big fun at the gas station, as the attendant stands there waiting for the pump to shut off. . .and waits. . .and waits. . .and wonders where 22 gallons of fuel are going.
bigcigarjeff
PostPosted: Mon Apr 21, 2014 9:02 am    Post subject: Email me Rasta, gas gauge issue Reply with quote
Hi..I just did the tank conversion on my 924 S...did you have any issues with the fuel gauge in the dash..did you have to recalibrate the gauge needle..Im asking because the other day my low fuel level light came on and seemed earlier than normal...granted I am unsure of the reliability of the gauge sender since it was used with my donor tank, and my fuel level gauge is a little jumpy anyways, but was wondering if you had to do anything to the gauge itself since they are calibrated differently from 944 to 924 senders..
Email me, jeff, usairbearphx@yahoo.com
PostPosted: Mon Apr 21, 2014 9:13 am    Post subject: Reply with quote
Gauge works just as stock. Therefore, bad grounds, old wiring, or flaky sending unit will give odd results...just like the stock setup.
bigcigarjeff
PostPosted: Mon Apr 21, 2014 9:22 am    Post subject: Reply with quote
Or maybe add this to correct the signal
http://www.docskustom.com/shop/viewitem.php?productid=32
PostPosted: Mon Apr 21, 2014 11:00 am    Post subject: Reply with quote
Yeah, it doesn't need correcting. Late sender works with early gauge. You have another problem.
bigcigarjeff
PostPosted: Tue Apr 22, 2014 5:13 am    Post subject: Reply with quote
Ok cool..must just be the sender..it was used and didn't know the condition..should have checked it before I installed...and maybe the fact that I only put 3 gallons of gas in after the install to begin with and maybe just functioning normally..LOL..forgot about that
MikeDanger
PostPosted: Mon Nov 24, 2014 1:11 pm    Post subject: Reply with quote
ok so what is the difference in weight? and what does the plastic one weigh?
Jay Wellwood
PostPosted: Sun Sep 15, 2019 10:13 am    Post subject: Reply with quote
Anyone save the original photos?
The photo bucket ones are a little fuzzy, but I can make out the intent. Would be great if the original pics were available for better clarity though.
Great write up BTW - thanks for sharing!
Jay Wellwood
A couple of Audi's and a few Porsche's
timwil
PostPosted: Wed Jul 26, 2023 7:42 pm    Post subject: Reply with quote
Hi, Do you know what clearance the plastic fuel tank should have to the trunk floor?
Many thanks!
______________
07 e91 318i
78 924 NA
Page 2 of 2
