gml
Joined: 04 Mar 2021 Posts: 133 Location: Ontario Canada
Posted: Thu Jun 01, 2023 10:56 am Post subject: what’s this wire coming out of the dashboard/center consol |
it’s brown/red
two wires joined together
one end has two female spade connectors and is coming out of the dashboard gauge cluster area
the other end terminates in a plastic connector with a round pin on the + and a male spade on the -. this end of the wire comes out around the stereo insert just in front of the shifter
these are definitely the same wire as indicated by tugging on either end. neither end was ever plugged into anything when i got the car. first noticed it when i took the dashboard gauge cluster out
what could this wire be? also worth noting my car has not had a stereo in it since i’ve owned it. there’s a lot of disconnected wires for the speakers and the one end of this wire is located around those wires. however the other end comes out around the gauge cluster which is odd
pictures: https://imgur.com/a/ki2pMLI _________________ George
1982 924 NA 5-speed |
chuck21401
Joined: 20 Feb 2005 Posts: 607 Location: Annapolis, MD
Posted: Sat Jun 03, 2023 6:28 am Post subject: |
My guess is a speaker wire of some kind. Odd plug. _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
Beartooth
Posted: Sat Jun 03, 2023 6:42 am Post subject: |
I'd also guess toward a speaker wire. I'm pretty sure I've seen that style of plug for an audio wire connection, but can't remember where. _________________ 1980 931 diamond in the rough |
gml
Posted: Sun Jun 04, 2023 12:53 am Post subject: |
Found it! It seems to be the wire that connects the speaker in the center of the dashboard to the system. Number 9 in the PET diagram here.
https://imgur.com/a/3CmRaUE _________________ George
gml
Posted: Thu Jun 15, 2023 10:58 am Post subject: |
there’s another one I am struggling to track down. https://imgur.com/a/Bz6kdbh
white wire, female spade, it's got thick black insulation. it goes under the steering column somewhere, can't find the other end. it's not constant power, not ignition power, not a ground. _________________ George
