Heavy vibration in steering wheel at highway speeds
Goto page Previous  1, 2, 3
kondzi
PostPosted: Sat Mar 25, 2023 3:00 am    Post subject: Reply with quote
Nope, this is not normal. Everything should be solid and not moving/knocking at all. Only turning with the driving wheel. Try to locate where these knocking come from. In 911 there is a problem at the shaft near the driving wheel hub, there is a thin collar inserted into the bearing or so to stabilise this in an easy way. Just like in a VW bug.... See where the play is and try to work on it.
This is the fix for 911/VW Bug:
Konrad
'89 951 US
'81 931 RoW (TBD)
bureau13
PostPosted: Sun Mar 26, 2023 12:06 am    Post subject: Reply with quote
Thanks for that. It does feel like the sort of thing that could be responsible for the vibration in the steering wheel. I will try to narrow it down.
1986.5 Silver 928S
2008 Volvo XC90 (Daily)
Past lives (I miss them all):
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
1987 RX-7 Turbo II (Sold)
1985 RX-7 GSL (Stolen)
bureau13
PostPosted: Mon Mar 27, 2023 1:45 am    Post subject: Reply with quote
OK, so after further investigation, the movement is definitely coming from the end of the steering "drive shaft" (that's what they call it in PET) that is closer to the firewall. It seems rock solid at the rack. I can't grab the steering wheel and move it around though, so I don't think it's coming from the cabin end of the steering column. I'm guessing it's where the column mates to the firewall side universal joint. But PET doesn't have a picture of how that fits together. I would guess either that u-joint the bearing at the other end of the steering column from the driver. I can't see that from where I'm looking, maybe it's more visible from underneath.
1986.5 Silver 928S
2004 RX-8 (Wrecked)
1993 RX-7 (Sold)
Page 3 of 3
