Megasquirt Experts Wanted!
joewest
PostPosted: Thu Aug 18, 2022 7:12 am    Post subject: Reply with quote
Hi all,
Just quick update on the project. Lots of small tidy-up items to complete before sending it off to the dyno shop. Even poorly tuned, the throttle response and pull is awesome! I will post an in car drive video once a few more bits get put on.
'79 924 Supercharged / Track Prepared
'80 931 Daily Driver - Sold
"The number of posts in my profile may represent the number of times I have screwed something up...and admitted it here."
PostPosted: Thu Aug 18, 2022 9:23 am    Post subject: Reply with quote
Looks quite nice
PostPosted: Thu Aug 18, 2022 4:57 pm    Post subject: Reply with quote
Awesome setup, we need videos of this thing!
PostPosted: Fri Aug 19, 2022 3:32 am    Post subject: Reply with quote
Portland, Oregon = Home of the Coolest Toofahs!
PostPosted: Fri Aug 19, 2022 11:20 pm    Post subject: Reply with quote
Nice! So clean! An inspiration
Can I ask what you used for the firewall insulation? Harder to find something like this in silver rather than gold
PostPosted: Fri Aug 19, 2022 11:50 pm    Post subject: Reply with quote
Lots of great options here, reasonable prices, I use this stuff a lot on my prototype...
https://www.designengineering.com/products/heat-control/
jacobroufa
PostPosted: Sat Aug 20, 2022 2:17 am    Post subject: Reply with quote
Wow Joe! What a sweet project!
I am almost to the point where I will want to reach out and discuss my own Microsquirt-run supercharged 924. I'm using a slightly different approach than you with a different charger and keeping the CIS, but going with FrankenCIS firmware and eWUR for complete control. I will also be using an EDIS timing setup.
I would love to compare our setups more in depth!
1980 Porsche 931
1981 Porsche 924 Weissach
joewest
PostPosted: Sat Aug 20, 2022 2:39 am    Post subject: Reply with quote
Vaughan linked the exact product I used. Heat Screen self-adhesive and get a roll of the matching tape to finish the edges. I bought it from Summit Racing. Running this material and the OE rubber seal at the top of the firewall WITH the belly pan and splitter has reduced the engine bay temperatures a bit. This was before these significant mods for which I have no data to verify if this is still the case.
Hit me up Jacobroufa. What you describe is quite different, but I may have a few "lessons learned" than could save you headaches. The megasquirt is epic once working. SO much flexibility and no more CIS hard starts. Fires up perfectly after a hard run and heat soaking.
I fixed the serpentine belt alignment issue (see engine bay image in earlier post) this AM and should be able to post a video this weekend. Notice the "jumped" belt! The alternator slid back in its adjustable mounting bracket and took the belt with it by one rib.
PostPosted: Sat Aug 20, 2022 5:28 am    Post subject: Reply with quote
SO MUCH THIS!!!
Switching over to MS let me love my Turbo again, after spending years not driving it because it was too unreliable, never knew if I could get home with it.
Now it sits while I work on long-overdue cosmetic improvements! LOL - though it's too hot right now to be all that comfortable, TBH.
Car looks lovely Joe... nice work.
PostPosted: Mon Aug 22, 2022 7:38 pm    Post subject: Reply with quote
Lovely execution Joe. Absolute credit to you.
joewest
PostPosted: Tue Aug 23, 2022 2:00 am    Post subject: Reply with quote
Thanks for the kind words guys!
Here is a very short (and not very exciting) video of my testing the serpentine belt issue fix:
https://youtu.be/EHFiANvuXNM
Lots of tuning to do this weekend to address the dip when the throttle opens and to add an over-run safety. Then I would like to do more data logging and wide open throttle pulls.
FoundSoul
PostPosted: Tue Sep 13, 2022 8:55 am    Post subject: Reply with quote
joewest wrote:
Hi all,
Looks like I got to the party a bit late man, but wow what a beautiful car!
I just started writing a series that might have been helpful when you were first looking for MegaSquirt Knowledge/an expert in the field. Would love to hear your thoughts, and if it can help anyone else... please feel free to share it.
I've got the overview and three chapters posted up now, should have a forth posted up later this week.
The DIY EFI Tuners Guide – How to Install, Configure, and Tune EFI!
Jerry Hoffmann aka 'FoundSoul'
Founder/Owner DIYAutoTune.com and AMPEFI.com
Equal Opportunity Car Junkie
PostPosted: Tue Sep 13, 2022 8:58 am    Post subject: Reply with quote
Heyyy.. Welcome to the board!
FoundSoul
Thanks man!
joewest
PostPosted: Wed Sep 14, 2022 1:37 am    Post subject: Reply with quote
Hi Jerry,
I would love to provide any information about the build to support your efforts on your writing project. I particularly love the fact that there is an acronym glossary, which i believe will reduce barriers for us all.
Currently, I am fixing a serpentine belt vs. alternator alignment issue this weekend but should be off to the dyno shop to see some actual data shortly. TunerStudio shows that there is about 2.34lbs of boost at 6500RPM (MAX) with the stock pulley on the supercharger. A nice safe place to start tuning and experimenting with pulley diameters.
Keep in touch!
Page 5 of 6
