1977 Porsche 924 Non-Working Headlamp Doors
TommyPorsche
PostPosted: Sun Oct 31, 2021 8:49 pm    Post subject: 1977 Porsche 924 Non-Working Headlamp Doors Reply with quote
Greetings,
Has anyone dealt with non-working headlamp doors? Or, perhaps an approximate cost estimate on such a repair?
Also, might someone know the approximate cost estimate on replacing a timing belt? The original repair manuals are present. I would consider myself a step up for an amateur mechanic. Is this something only left to a professional?
Any advice or information is greatly appreciated.
Thanks!
Tommy
North Dakota
Eliza
PostPosted: Thu Nov 04, 2021 11:13 pm    Post subject: Reply with quote
Hello Tommy,
do you mean non-working pop-up headlights? If yes, if you can specify what does and doesn't work ( the pop-up part or the light part, for a start ) help will be more readily available.
Whatever it is that turns out not to work, it should be fixable and not require paying somebody else to do the work for you.
Belt. I don't do mine, I rather pay my mechanic the 70 EUR for parts and labour he charges me. I am certain that most others here change theirs themselves.
Eliza
1985 924 NA RoW
1981 931 S2 RoW
anthonimartini
PostPosted: Fri Nov 05, 2021 2:20 pm    Post subject: Reply with quote
the belt is easier to change then diagnosing the headlight problem. depending on the options on the car and if you are changing the seals a timing belt can be done in about ten minutes. you must check and adjust ignition timing after a timing belt install.
get this!
https://www.ebay.com/itm/324783587893?hash=item4b9e9c4235:g:Fx4AAOSwyvBhEIaW
ive saved alot of 924's
current:
79 MochaSchwartz 931
83 944
87 924S
formerly known as turbellion, lost password.
