My brake lights don't work!
Supreme
PostPosted: Tue Jul 13, 2021 7:40 am    Post subject: My brake lights don't work! Reply with quote
Hi everyone, 1979 924 n/a here.
The rest of the lights are working but the brakes don't light up at all. I heard that I need to replace the switches on the master cylinder.
My question is, are the two brake light switches for each brake light? (Left/right)
Also, is it strange both would be out?
And lastly, are they easy to replace? I bought new ones and haven't done this before. Is there any chance brake fluid brake will leak out while replacing?
Thanks for looking!
[/img]
PostPosted: Tue Jul 13, 2021 8:48 pm    Post subject: Reply with quote
Brake fluid would definitely leak out... but if I were you I'd check for power and ground first. Make sure the electrical system is good. If you short out the switch, do the lights come on? If not, replacing the switches is a waste of time.
Supreme
PostPosted: Thu Jul 22, 2021 1:55 pm    Post subject: Reply with quote
Thanks, I'll give this a try!
1979 924 n/a Mexico Beige
