chuck21401
Joined: 20 Feb 2005 Posts: 606 Location: Annapolis, MD
Posted: Sat May 22, 2021 7:28 am Post subject: |
Wow, just wow. If I lived closer I'd come over just to get a whiff of that new car smell.
Posted: Sat May 22, 2021 10:09 pm Post subject: |
People have scoffed at the price of Thomas' repro dashes. But look at the quality in those photos.
Swapping is super easy. The only issue is being scared to nick, scratch or mark that perfect new dash.
Good luck. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
chuck21401
Posted: Mon May 24, 2021 2:33 am Post subject: |
| Carrera RSR wrote: | | Swapping is super easy. |
So far so good...taking my time. I'm learning that 40 year old plastic parts are brittle. I've had to made some new tabs with "Plastex" and fill some cracks. One small section of the center console fell apart as I was removing the switch for the electric mirror. I was able to repair that with Plastex as well. Source: https://www.plastex.net (also on Amazon, shipping is less)
I suppose I could just buy another HVAC panel Ebay (or not worry about it), but wanted to see if I could do it.
Missing tab circled. Using putty to make mold from the tab below.
Mix up the Plastex and drop mixture into mold
Allow to harden. Use razor blade to trim and emory board to sand down.
New tab
 _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler
chuck21401
Posted: Mon May 24, 2021 2:35 am Post subject: |
| Rasta Monsta wrote: | | Location: PacNW |
I'm right around the corner. Drop by whenever.
Still waiting on videos of the 931 S3 in action.  _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler
chuck21401
Posted: Mon May 24, 2021 2:39 am Post subject: |
Almost ready to remove the dash.
 _________________ 1981 Porsche 931 w/S1 engine & euro g31 transaxle. Water-cooled intercooler |
chuck21401
Posted: Mon May 24, 2021 5:44 am Post subject: |
This is getting complicated.
Luckily installation is the reverse of removal.
jacobroufa
Posted: Mon May 24, 2021 9:56 pm Post subject: |
| chuck21401 wrote: | New tab
Very nice! _________________ 1980 Porsche 931
1981 Porsche 924 Weissach |
safe
Posted: Mon May 24, 2021 10:22 pm Post subject: Re: Removing cracked dashboard and installing new Werk924 da |
| chuck21401 wrote: | I'm finally getting around to installing the new dashboard I bought from Werk924.
[/b] |
Is it fibreglass framed?
How does the colour, shine and grain structure compare to the original? _________________ /Magnus, Stockholm Sweden
Porsche 931 -79
Porsche 911 -77, 3.2 Targa
Porsche 911 -69, 3.6, Coupe |
chuck21401
Posted: Tue May 25, 2021 3:17 am Post subject: Re: Removing cracked dashboard and installing new Werk924 da |
| safe wrote: | Is it fibreglass framed?
How does the colour, shine and grain structure compare to the original? |
I believe that it is fiberglass. It feels very solid though.
Here are some comparison pictures. The old dashboard has some lighter brown highlights....not sure how to describe. Also not sure if that is the result of 40 years of sunshine. The texture is very similar to me.
But truthfully when I look at the old dash, the only thing I see are the cracks.
chuck21401
Posted: Tue May 25, 2021 3:25 am Post subject: Dash Vents |
Removing the side dash vents didn't go so well. I barely touched the tabs and they broke off. The plastic is so brittle!
Anyone have a source for mint condition, non-faded, brown dash vents?
Maybe I could find a nice set from an early 944?
These will work for now I guess.
Posted: Tue May 25, 2021 4:12 am Post subject: Re: Dash Vents |
| chuck21401 wrote: | | The plastic is so brittle |
This is a special German material found throughout our cars. The same material comprises many critical electrical connectors.
Its name is "Brittelsheiß." _________________ Toofah King Bad
chuck21401
Posted: Tue Jun 01, 2021 1:01 pm Post subject: |
Making some progress.
The new dashboard is in the car but still need to make some adjustments and still fighting with the center console. So many wires.
I also had the odometer on the speedo fixed while it was out of the car. Also replaced the ignition switch while I was in there.
As you can see, the side vents are no longer brown. I need to replace the trim piece for the headlight switch; that should be fairly easy to find in better shape. I replaced the trim piece for the hazards and rear window defogger....nice match.
chuck21401
Posted: Fri Jun 11, 2021 12:20 am Post subject: |
More progress. Still need to adjust the glove box a bit.
I installed the switch for the intercooler pump/cooling fan in the center console opposite of the stereo fader knob.
Posted: Fri Jun 11, 2021 3:52 am Post subject: |
So nice! I got to see one first hand recently in Bart's Martini Resto. Really nice dash
Chuck, that little mold idea was brilliant _________________ 1980 931 since 1989
