rear wheel bearings outer spacer ring
Benino
PostPosted: Fri Mar 12, 2021 4:48 am    Post subject: rear wheel bearings outer spacer ring Reply with quote
the inner race on my outer rear wheel bearing cracked. It's been a long time since I did wheel bearings and I don't remember exactly how the outer spacer that gets torqued against the wheel bearing inner race looks. Does anyone have one laying around to compare?
I'm wondering if that indented grove on the surface that presses against the wheel bearing race is supposed to be there of if that's wear.
Just for fun, here's a picture of how the inner race of the wheel bearing looked.
1980 Porsche 924 N/A USA
1980 Porsche 924 turbo USA
1987 Porsche 944S USA
!tom
PostPosted: Fri Mar 12, 2021 7:28 am    Post subject: Reply with quote
It's been a long time, but I thought there was a spacer between the inner races.
Nut -> outer ball bearing -> spacer -> inner roller bearing -> spindle
78 924 NA
5-lug
Benino
PostPosted: Fri Mar 12, 2021 11:29 am    Post subject: Reply with quote
Here's the stub axle with all three spacers on it.
PostPosted: Sat Mar 13, 2021 1:20 am    Post subject: Reply with quote
That's wear, and if the hardened outer spacer is so worn, I'd recommend replacing ALL of them.
We've snapped a few stub axles racing, and I have come to blame it on worn spacers allowing the nut to thread too far down, resulting in cutting new threads in the end of the stub axle, weakening it and popping the axle at the base of the threads.
Thankfully, we have disc brakes on the rear (M471), and the calipers do a great job of holding the rear wheels on till the car comes in.
Also thankfully - this is a common SuperBeetle part. I just found a source for chromoly spacers, including the tube spacer, and got a set. Haven't installed 'em yet, they go on this spring, but hoping this resolves our axle snapping issues...
Pretty sure this was the set I got:
https://dunebuggywarehouse.com/rear-axle-spacer-set-6-irs.html
Yay for cheap VW parts!!
Benino
PostPosted: Sat Mar 13, 2021 2:10 am    Post subject: Reply with quote
Thanks! I appreciate the info. I thought that might be wear but it was so uniform, it was hard to tell. I ordered the dune buggy parts. I'll be off-roading in no time!
Benino
PostPosted: Tue Mar 23, 2021 1:23 pm    Post subject: Reply with quote
I made a time-laps video of installing the new spacers and wheel bearings. Thought I'd share it.
https://youtu.be/n7dSzYJmGCI
PostPosted: Tue Mar 23, 2021 8:54 pm    Post subject: Reply with quote
Very nice!
Was happy to see the torque wrench come out for the backing plate!
PostPosted: Tue Mar 23, 2021 11:24 pm    Post subject: Reply with quote
Ha, that video is pretty fun
