Moparboy72
Joined: 29 Jul 2014 Posts: 49 Location: Naperville, IL
Posted: Wed Mar 04, 2020 1:12 am Post subject: Connecting Rod Revision |
I am in the process of building a short block for my 931 using a spare 1977 engine as a base. It has been interesting finding out which parts carry over and which do not. The current PET/pdf parts catalogs only show current parts with no indication of previous numbers or supercisions.
One case I found interesting was through reading an old technical bulletin , number 78-01.
This bulletin outlines that the connecting rods have been updated and now have an oil spray hole to improve piston cooling (near the exhaust valve). The new rods were installed starting with XH 005 193 and XF 003 260.
The XF rods that I have are earlier and do not have the oil hole. Has anyone drilled this hole?
Thanks,
Andrew |
Joined: 29 Jul 2001 Posts: 9076 Location: Royal Oak, MI, USA
Posted: Wed Mar 04, 2020 3:22 am Post subject: |
I seem to recall that there is a boss through which this is drilled... presumably to add strength around the hole. Which makes me concerned about the idea of drilling the hole without reinforcement...
Edit - not the easiest to see, but here's a pic, and you can see the little bump for oil down at the base of the web on the big end...
https://www.facebook.com/photo.php?fbid=10212999630420297&set=a.10212999625340170&type=3&theater _________________ Vaughan Scott
Moparboy72
Posted: Wed Mar 04, 2020 3:47 am Post subject: |
Thanks for the post and photo link Vaughan. I was searching around and could not see it as clearly as you show.
The tech bulletin shows a grainy black and white photo. I will double check but, I am quite certain the early rods are uniform in their forging, as in no bump/material for oil hole.
It seems the safest course of action would be to search out a later set of rods.
Thanks again,
Andrew |
Posted: Wed Mar 04, 2020 7:34 am Post subject: |
There is a post around here somewhere where Dan slotted the rod for the same purpose ...
I don't find the post of all the tech discussion but you see it on this page
http://www.924board.org/viewtopic.php?t=31912&postdays=0&postorder=asc&start=60 _________________ 1980 931 since 1989
!tom
Posted: Thu Mar 05, 2020 12:24 am Post subject: |
That was the thread I remember! _________________ 1980 931 since 1989
Moparboy72
Posted: Thu Mar 05, 2020 12:08 pm Post subject: |
| Thanks guys! It is nice to see another solution to use these early rods ( by adding a slot). I did double check and the early rods are uniform (no bump). |
