Haste Makes Waste (-_-)
K-Roll931
PostPosted: Mon Mar 11, 2019 12:29 pm    Post subject: Haste Makes Waste (-_-) Reply with quote
In my haste to get to setting the timing on my 931, I plugged the wires on the back of my tach wrong/backwards. Even worse, possibly connecting power straight to the ground. And now I've not only got a dead tach (waste), I've got a dead 1980 931 GREEN tach.
Luckily, the wires are fine, I've still got ideal voltage and continuity. But I would rather drive blind than replace it with the regular white gauge face.
Hopefully I've got a replacement lined up tomorrow, or I'm gonna have a helluva time trying to buy an S1 tach and not the whole cluster, or swapping faces with a regular 924 tach.
Don't be like me and try to wire off memory, look at the flow diagram, as frustrating as it can be. Take your time, check as many references as possible, and ask any questions before you proceed.
'80 931 M471 - Dolomite Gray -> Monaco Blue
PostPosted: Mon Mar 11, 2019 5:39 pm    Post subject: Reply with quote
Did you find out whats the right way to connect the wires?
K-Roll931
PostPosted: Tue Mar 12, 2019 1:16 am    Post subject: Reply with quote
Yes I did, and I'll never forget it now.
Kenodog
PostPosted: Tue Mar 12, 2019 2:32 am    Post subject: Reply with quote
Damn brother, that sucks.
Lee
1979 Euro 931, Olive
1981 931, Sabine
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140
PostPosted: Tue Mar 12, 2019 4:32 am    Post subject: Reply with quote
well spit it out ffs, i'm about to re-install my tach and a friend's tach and i cant see the signs on the plastic bit.
Kenodog
PostPosted: Tue Mar 12, 2019 4:43 am    Post subject: Reply with quote
1981 931, Sabine
2024 KLX300
2024 KLX140
K-Roll931
PostPosted: Tue Mar 12, 2019 7:34 am    Post subject: Reply with quote
Well heck all ya had to do was ask!
Black goes to 12+, the single green goes to 1, and the brown is ground (-).
PostPosted: Tue Mar 12, 2019 6:32 pm    Post subject: Reply with quote
thanks i cant see the plastic markings on mine so i'll just have to take the wiring and position it like you did in the picture, assuming thats the right way
PostPosted: Tue Mar 12, 2019 6:47 pm    Post subject: Reply with quote
I got a Sharpie and marked my gauge with wire colours before I removed the wires many years ago. Gauge only been out once since and those markings saved me and the gauge
PostPosted: Tue Mar 12, 2019 9:35 pm    Post subject: Reply with quote
Yes, sharpie is the answer...
K-Roll931
PostPosted: Mon Mar 25, 2019 2:31 pm    Post subject: Reply with quote
Got my "new" tach earlier this week, wired it properly this time, and was finally able to set ignition timing!! Now I have to fiddle with the fuel mixture....
