Is a Bosch Fuel Pump Comparison Table available?
PostPosted: Wed Sep 27, 2017 12:06 am    Post subject: Is a Bosch Fuel Pump Comparison Table available? Reply with quote
Recently needed to replace the external fuel pump on a Toofah Turbo S2 and was unable to find cross references available on-line of the values (pressure/litres per hour) of Bosch fuel pumps.
From Bosch itself I was able to get their Cross Reference Information, but as useful as it was to determine supercessions, no metrics were listed.
The Aussie distributor claimed no such information was readily available......I find that unbelievable!
The car was delivered with a 0 580 254 967 short neck pump, but this is not sold in OZ by Bosch, even though I was able to find several examples still available overseas, but at great cost. Wanting to replace my failed pump with a like-for-like short neck, I was steered to a 0 580 254 053, which on the Bosch list is supposedly a direct replacement. Interestingly, it is also a replacement for the 80-83 911SC, and when I checked the PET, sure enough the 924T S2 and late 911 SC have the same fuel pump part number 911 608 102 02.
So everything should be sweet, but.......I'm still having fuel delivery issues (detailed in another post elsewhere), and yes I know I have to systematically check a whole range of things, but I really would like to know if this new pump is performing as required.
Anyone know of such a comparison table??
Johann
PostPosted: Wed Sep 27, 2017 12:59 am    Post subject: Reply with quote
According to my local parts dealer and Official Porsche Centre
911.608.102.02 = Bosch 0 580 464 126
I think 0 580 254 053 is an older reference number. I checked your specs and you should be fine.
Your pump(0 580 254 053) has the following specs:
Pressure - 5bar
Flow - 175 liter per hour
PostPosted: Wed Sep 27, 2017 1:48 am    Post subject: Reply with quote
Yo Johann
So where did you get the specs from?
Incidentally, you're probably right about my list being old (though I did pull it off a Bosch website only weeks ago), as it doesn't even list the 0 580 464 126.
Was it you in another post somewhere, that floated the figures of 6.5 bar and 255 lph?
Does anybody know what our cars should have....that is a figure from the factory? I can't find anything in the FSM.
PostPosted: Wed Sep 27, 2017 2:04 am    Post subject: Reply with quote
My old leaky pump and the new one I replaced this spring:
Mine came with the long neck...but if you do a search on Bosch's website for its products you can find the equivalent specs of the pump I ordered. Its the right thing for the 924.
580 254 962
Johann
PostPosted: Wed Sep 27, 2017 7:01 am    Post subject: Reply with quote
I found this on the Dutch 924 Site. It is outdated but it lists both the 053 and 962 Morghen mentions as valid replacement pumps
TECH. INFO PORSCHE 924.
From the factory, the Porsche 924 has the following pump mounted 0 580 254 967. The table then refers to 0 580 254 053. The pumping capacity is 228 liters per hour at a system pressure of 5 Bars.
0 580 254 053
Replaces:
0 580 254 967
0 580 254 968
0 580 254 969
Recommended price € 179,-
0 580 254 909
Replaces:
0 580 254 931
0 580 254 932
0 580 254 934
0 580 254 949
0 580 254 957
0 580 254 958
0 580 254 959
0 580 254 960
0 580 254 961
0 580 254 962
0 580 254 964
0 580 254 965
0 580 254 966
0 580 254 970
0 580 254 971
0 580 254 972
0 580 254 980
0 580 254 981
Recommended price € 175,-
0 580 254 910
Replaces:
0 580 254 921
0 580 254 922
0 580 254 927
0 580 254 928
0 580 254 942
0 580 254 943
0 580 254 952
0 580 254 956
0 580 254 973
0 580 254 974
0 580 254 911
Replaces:
0 580 254 945
0 580 254 946
0 580 254 950
0 580 254 951
0 580 464 030
0 580 464 034
0 580 464 040
0 580 464 041
0 580 464 069
Replaces:
0 580 464 021
0 580 464 022
0 580 464 024
0 580 464 025
0 580 464 027
0 580 464 028
0 580 464 037
0 580 464 042
0 580 464 044
Recommended price € 165,-
0 580 464 070
Replaces:
0 580 463 008
0 580 463 013
0 580 463 014
0 580 463 015
0 580 463 016
0 580 464 019
0 580 464 020
0 580 464 023
0 580 464 032
0 580 464 033
0 580 464 038
0 580 464 048
0 580 464 050
0 580 464 051
0 580 464 056
0 580 810 046
Recommended price € 169,-
0 580 464 085
Replaces:
0 580 463 010
0 580 463 011
0 580 463 012
0 580 463 013
0 580 463 014
0 580 463 015
0 580 463 016
0 580 463 017
PostPosted: Wed Sep 27, 2017 9:22 pm    Post subject: Reply with quote
Thanks Guys.
Yes, I did finally get the fuel pump working....in fact it was singing. Always seems to work when fuel is added to the tank!
On those Bosch websites that you have accessed, Johann, did any actually provide the Bar/LPH figures for each pump?
What I've found is just part numbers and to get a value for each pump entails contacting a seller.
A table of various pumps and their performance specs would be great.
Cheers Pete
