Schwami
Joined: 11 Apr 2016 Posts: 85 Location: Wisconsin Green Bay
Posted: Sat Sep 02, 2017 1:53 pm Post subject: 110 octane leaded fuel |
Any ideas what 2 gallons of this blue flame fuel would do to my injection, compression etc systems? _________________ 1979 924 Diamant Zweischicht.
Serial # 9249201031
XG 309 543 engine code.
2012 Golf Sportwagon TDI |
3forall
Posted: Sat Sep 02, 2017 10:10 pm Post subject: |
Injection- Nothing unless it has significantly more/less detergents compared to regular pump gas, but I would assume it's similar.
Compression- Fuel won't change your compression but since you would be running much higher octane you would lose power unless you change either timing or the compression ratio of your engine.
Systems- If you have a catalytic converter on your car the lead in the fuel would wreck it, making it permanently ineffective.
There's no reason to put 110 octane leaded fuel into a street car. _________________ 1981 924 Weissach edition
1982 931 - Megasquirt and liquid intercooler
1969 911 |
Schwami
Posted: Sun Sep 03, 2017 6:58 am Post subject: |
Thanks. Now I don't need to justify $7.65/gal. I removed the cat earlier this year, put a header and replaced the pipes with only a muffler. Back to the 87 octane. :) _________________ 1979 924 Diamant Zweischicht.
Serial # 9249201031
daniel
Posted: Tue Sep 05, 2017 10:41 am Post subject: |
The only advantage without upping your compression is you can advance timing and run a bit richer. Gains will be minimal without a compression increase _________________ Over the top of skyline, total brake failure.... hit the wall at over 200 kp/h at the dipper, so anyone who has to brake for the esses is a pussy.
1989 944 Cabriolet |
