Ole Petter
Posted: Wed Aug 16, 2017 10:38 pm Post subject: Lenso BSX wheels? Fit on 1984 924? |
Hi!
Does anyone have experiences vith the Lenso BSXwheels? I want tomrefurbish a set of teledials, but was told it would be cheaper to buy new ones...
So I am considering the Lenso in 7x15 et20... They will not guarantee that they fit the wheelarches well, so maybe someone can help with advice??
Many thanks! |
Posted: Wed Aug 16, 2017 11:10 pm Post subject: |
these?
 _________________ Supercharger and EFI kits
https://www.the924.com |
Sunset924
Posted: Sat Aug 19, 2017 10:59 am Post subject: |
If I had to venture a guess, I would say they would fit without issue. These are not the same wheels you are looking at but the width and offset are the same:
16x7 et20 up front with 185/55/16 sidewall of the tire is flush with the outside edge of the fender
16x7 et20 in the rear with a 20mm spacer (final fitment of et0) with a 225/45/16 you can just place a pinky finger between the sidewalk and an aggressively rolled rear wheel arch
Car has been lowered significantly and have never rubbed even during high speed cornering. Hope this info helps a little. |
