Rhubie
Posted: Mon Jul 17, 2017 2:01 pm Post subject: FT/LBS on fuel distributor |
| Anyone know the exact FT/LBS of torque on the fuel distributor when putting back together? |
Eric P
Posted: Tue Jul 18, 2017 3:21 am Post subject: |
I assume you're talking about the torx screws? I read online that the spec is 7-10 N-m. I tightened mine to 75 in-lb which is right in the middle of that spec. It's such a small screw that you should get a 1/4" drive torque wrench that reads in in-lb. Anything that reads in ft-lb won't be accurate enough.
Be careful if you're torquing the big nut on the bottom. I believe the spec on that one was fairly low. I can't remember off the top of my head, but I think it was basically hand tight. _________________ 1980 924 NA, US model
1987 924S, US model |
Rhubie
Posted: Tue Jul 18, 2017 4:45 am Post subject: |
Yeah I got you.. I was just gonna hand tighten the nut on the bottom with another 1/8 turn _________________ 1980 Porsche 924 Weissach Commemorative Edition |
