toast54
Joined: 08 Sep 2014 Posts: 106 Location: Oklahoma City OK
Posted: Tue Jul 11, 2017 11:09 pm Post subject: 928 |
| I see a lot of V8 swaps in 924's using GM engines but not so many using a 928 engine. Is there a reason? Cost and parts availability, perhaps? |
v2rocket_aka944
Joined: 05 Jan 2009 Posts: 49 Location: Nashville, TN
Posted: Sat Jul 15, 2017 2:04 am Post subject: |
mostly just physical size...
a 928 engine is about 28" from valve cover to valve cover and depending on year weighs up to 600lbs with accessories...
it's just a giant hunk of metal that in best original form only put out 350 hp (if you can even find one of those engines).
it does FIT in a 924/944 chassis but you can get the same or more power and save 100+ lbs using an LS-based engine or other and have a lot more working room. |
toast54
Posted: Sun Jul 16, 2017 1:02 am Post subject: |
| Not that I'm looking to swap out engines, but thanks for the info |
