WUR question
brian19600
PostPosted: Sun Mar 26, 2017 10:21 pm    Post subject: WUR question Reply with quote
If, with the engine off and the fuel pump jumpered, you power up the heater on the wur, should it show gradually increasing control pressure or is it required that the engine be running?
PostPosted: Sun Mar 26, 2017 10:22 pm    Post subject: Reply with quote
It should gradually change, yes, just needs electrical power to make that happen.
brian19600
PostPosted: Sun Mar 26, 2017 10:39 pm    Post subject: Reply with quote
Ok, thanks for the quick reply! It isn't, so I'll have to pull it off and take it apart. At least this one is showing 1 bar cold (45F). The other one that was on there wasn't reflecting any change when switching from system to control.
