German Godzilla. The creation of a (2-tone) Green Monster...
Goto page Previous  1, 2, 3 ... 9, 10, 11, 12, 13  Next
WEASEL149
PostPosted: Fri Mar 18, 2016 3:51 am    Post subject: Reply with quote
Manifold finished for now until everything is proven and running:-
1979 UK 932
WEASEL149
PostPosted: Fri Mar 18, 2016 3:58 am    Post subject: Reply with quote
It's time to finally finish off the inlet manifold and the rest of the intake system including this:-
1500CFM capable Spearco charge cooler. Has about 0.18psi pressure drop at 30 psi boost and 700CFM flow with a water cooling inlet temp of 45F.
1979 UK 932
gabo931
PostPosted: Fri Mar 18, 2016 4:30 am    Post subject: Reply with quote
The manifold looks great!
Are you able to use the pop up head lights with this setup? Or are you going to change for the GTS headlight?
1980 931 M471 LSD
WEASEL149
PostPosted: Fri Mar 18, 2016 4:38 am    Post subject: Reply with quote
Thanks! Either light set-up will fit I believe.
I was waiting for someone to ask the question but unfortunately everyone's going to have to wait 'til the end to find out
1979 UK 932
gabo931
PostPosted: Fri Mar 18, 2016 6:04 am    Post subject: Reply with quote
Can't wait to see it finished!
1980 931 M471 LSD
WEASEL149
PostPosted: Tue Mar 22, 2016 8:53 am    Post subject: Reply with quote
Fuel rail is fitted:-
1979 UK 932
WEASEL149
PostPosted: Tue Mar 22, 2016 8:58 am    Post subject: Reply with quote
Jaguar twin carb inlet manifold waiting to be butchered... :-
...and become a plenum inlet diffuser:-
1979 UK 932
WEASEL149
PostPosted: Tue Mar 22, 2016 9:00 am    Post subject: Reply with quote
Entrance bore is ~72mm, which will blend nicely with my 70mm throttle:-
1979 UK 932
WEASEL149
PostPosted: Tue Mar 22, 2016 9:03 am    Post subject: Reply with quote
Tacked on ready for welding:-
1979 UK 932
PostPosted: Wed Mar 23, 2016 7:31 am    Post subject: Reply with quote
24hrs since your post and no rsponses Wes......poor show
Get it finished and have the last laugh with lots of boost!!
PostPosted: Wed Mar 23, 2016 8:39 am    Post subject: Reply with quote
WEASEL149
PostPosted: Wed Mar 23, 2016 8:58 am    Post subject: Reply with quote
Rasta, is that a vacuum cleaner attachment? lol
That's what we compared the Jag flare to...
1979 UK 932
WEASEL149
PostPosted: Wed Mar 23, 2016 9:04 am    Post subject: Reply with quote
It's all good, I don't mind.
Sometimes silence or speechless is the best reaction...
I'm trying to get it finished, honestly
I can see light at the end of the tunnel now at least.
1979 UK 932
PostPosted: Wed Mar 23, 2016 5:42 pm    Post subject: Reply with quote
PRICELESS !!!
Good to have you on this board brother !
GeorgeV
PostPosted: Wed Mar 23, 2016 8:16 pm    Post subject: Reply with quote
Wes, it's very impressive. That manifold will flow very well. Keep the updates coming.
1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921
Page 10 of 13
